주요 콘텐츠로 건너뛰기
Roomba Pro Elite Drive Wheel Belts Replacement
SamGeorge
SamGeorge4 다른 기여자
최종 수정일 August 27, 2018
30 분 - 1 시간
조정
액션 샷
더 많은 이미지가 필요함
커뮤니티-기여 안내서
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Roomba Pro Elite Drive Wheel Belts Replacement, Drive Wheel Belt: 1 단계, 이미지 2개 중 1개 Roomba Pro Elite Drive Wheel Belts Replacement, Drive Wheel Belt: 1 단계, 이미지 2개 중 2개
    • Go ahead and remove the dust bin.
    • Then flip the roomba over and remove the battery.
  2. Roomba Pro Elite Drive Wheel Belts Replacement: 2 단계, 이미지 3개 중 1개 Roomba Pro Elite Drive Wheel Belts Replacement: 2 단계, 이미지 3개 중 2개 Roomba Pro Elite Drive Wheel Belts Replacement: 2 단계, 이미지 3개 중 3개
    • The upper housing is held in place by eight phillips #2 screws on the underside of the machine. Removing the four screws around the battery compartment is the most difficult step in servicing the robot.
    • The recess holes around the battery compartment, are 5.85 mm in diameter. The thinest old school #2 phillips I could find, has a shank diameter of 5.90 mm. Humm, did they do this on purpose to make working on these difficult?
    • Well, the easiest way I found to overcome this problem was to ream out the holes to 1/4 inch. I used the wrench from a tap and die set, an ordinary drill, and a drill collar; to carefully ream out the holes by hand.
    • If you don't have all that, you can use a regular drill. Be careful though not to hit the screw as the drill bit with strip it and make it very hard to remove. The factory sets these screws very tight and they are difficult to take out if they have not been removed before.
  3. Roomba Pro Elite Drive Wheel Belts Replacement: 3 단계, 이미지 1개 중 1개
    • Now go ahead and remove all eight screws. (please excuse the battery in the picture, you should have removed it back in step 1.)
  4. Roomba Pro Elite Drive Wheel Belts Replacement: 4 단계, 이미지 1개 중 1개
    • If you made it this far, the worst is past. Carefully maneuver the top housing until it comes free.
    • The control panel in the top is connected by a ribbon cable, detach it at the circuit board.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
SamGeorge
회원 가입일: 01/11/13
194 평판
안내서 1개를 작성함
5가이드 댓글
Thank you! You speed up my repair time to half
Michael Fiala - 답글
Great!
Now where can I aquire a new belt?
That is my biggest problem
Jef Hern - 답글
I also need a new belt, but can’t fine one either. Jef Hern, did you ever find one?
magicmickeydonna - 답글
You can get the same belt from the roomba 4000
LakeM0nst3r -
If you can’t find the belt the roomba 4000 uses the same belt or the discovery series
LakeM0nst3r -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 2,737
