주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi CSB125 Motor Replacement
필요한 것
  1. Ryobi CSB125 Motor Replacement, Motor: 1 단계, 이미지 1개 중 1개
    • Place the saw on a flat surface with the blade facing up.
    • Make sure that the saw is unplugged from any power source.
    댓글 쓰기
  2. Ryobi CSB125 Motor Replacement: 2 단계, 이미지 2개 중 1개 Ryobi CSB125 Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the bumper by using the T20 torx screwdriver to loosen the M5 x 20mm screw.
    댓글 쓰기
  3. Ryobi CSB125 Motor Replacement: 3 단계, 이미지 2개 중 1개 Ryobi CSB125 Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
    댓글 쓰기
  4. Ryobi CSB125 Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
    댓글 쓰기
  5. Ryobi CSB125 Motor Replacement: 5 단계, 이미지 3개 중 1개 Ryobi CSB125 Motor Replacement: 5 단계, 이미지 3개 중 2개 Ryobi CSB125 Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Use the #2 Phillip screwdriver to remove the four M4x16mm screws shown.
    • You will need to rotate the protective shell around in order to access them.
    댓글 쓰기
  6. Ryobi CSB125 Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the lower blade guard support assembly from the rest of the saw.
    댓글 쓰기
  7. Ryobi CSB125 Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Flip the saw over and place the saw down on a flat surface with the motor facing up.
    댓글 쓰기
  8. Ryobi CSB125 Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
    댓글 쓰기
  9. Ryobi CSB125 Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
    댓글 쓰기
  10. Ryobi CSB125 Motor Replacement: 10 단계, 이미지 2개 중 1개 Ryobi CSB125 Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Use the Phillips #2 screwdriver to remove the two M4x16mm screws holding down the end cover.
    • Pull off the end cover.
    댓글 쓰기
  11. Ryobi CSB125 Motor Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips #2 screwdriver to remove the M45x35mm screw holding down the motor housing.
    댓글 쓰기
  12. Ryobi CSB125 Motor Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the motor housing for access to the internal motor components.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Curtis Melo
회원 가입일: 10/31/19
1,093 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 117
전체 시간: 1,147
