주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi CSB125 Protective Shell Replacement
필요한 것
    1. Ryobi CSB125 Protective Shell Replacement, Protective Shell: 1 단계, 이미지 1개 중 1개
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      댓글 쓰기
    2. Ryobi CSB125 Protective Shell Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the bumper by using the T20 Torx screwdriver to loosen the M5 x 20mm screw.
      댓글 쓰기
    3. Ryobi CSB125 Protective Shell Replacement: 3 단계, 이미지 2개 중 1개 Ryobi CSB125 Protective Shell Replacement: 3 단계, 이미지 2개 중 2개
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      댓글 쓰기
    4. Ryobi CSB125 Protective Shell Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      댓글 쓰기
    5. Ryobi CSB125 Protective Shell Replacement: 5 단계, 이미지 3개 중 1개 Ryobi CSB125 Protective Shell Replacement: 5 단계, 이미지 3개 중 2개 Ryobi CSB125 Protective Shell Replacement: 5 단계, 이미지 3개 중 3개
      • Use the Phillips #2 screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      댓글 쓰기
    6. Ryobi CSB125 Protective Shell Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the lower blade guard support assembly from the rest of the saw.
      • Remove the protective shell.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Curtis Melo
회원 가입일: 10/31/19
1,093 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G1
3 회원들
안내서 5개를 작성함
4가이드 댓글
Instructions fail at step #5. Bottom-left screw is under the plastic blade guard which blocks removal of the screw. Blade guard covers the screw no matter how it’s positioned.
Michael Bluejay - 답글 공유
If you wiggle the plastic you can remove
I was able to remove… be patient it does work
Adrian Isbister - 답글 공유
Instructions also fail at step #6. I have no idea how to remove the plastic blade guard from the axle so I can transfer it to the new (replacement) blade guard.
I also was struggling… … but if you look closely there is a thin metal ring around the center plastic ring that the spindle runs through… this has a split in it…. I used a small flat Precision screwdriver (type used to tighten reading glasses,etc)and was able to pry at the split and remove the thin metal ring.
Once removed this frees the plastic guard and it drops right out.
Just reverse to reassemble.
This works… just be patient
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 36
전체 시간: 2,837
