주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A03s Screen Replacement
필요한 것
  1. Samsung Galaxy A03s Screen Replacement, Eject SIM card tray: 1 단계, 이미지 1개 중 1개
    • Remove the sim card by inserting a sim card tool into the sim card tray hole.
    댓글 쓰기
  2. Samsung Galaxy A03s Screen Replacement, Remove back cover: 2 단계, 이미지 3개 중 1개 Samsung Galaxy A03s Screen Replacement, Remove back cover: 2 단계, 이미지 3개 중 2개 Samsung Galaxy A03s Screen Replacement, Remove back cover: 2 단계, 이미지 3개 중 3개
    • This cover has a series of plastic clips that attach it to the frame. Use your opening tool to gently pry the plastic back cover off.
    • Be careful inserting your opening tool near the power button. This button contains a fingerprint sensor with a ribbon cable that’s attached to the back cover. Do not cut this cable while removing the back cover.
    댓글 쓰기
  3. Samsung Galaxy A03s Screen Replacement, Remove power button: 3 단계, 이미지 1개 중 1개
    • 2 plastic notches on the back cover hold the power button in place. Disconnect the power button from the back cover.
    댓글 쓰기
  4. Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: 4 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: 4 단계, 이미지 2개 중 2개
    • 18 screws secure the camera lens bracket and loud speaker. All screws are the same size. Use a Phillips screwdriver to remove the 18 screws securing the camera lens bracket and loud speaker.
    댓글 쓰기
  5. Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: 5 단계, 이미지 3개 중 1개 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: 5 단계, 이미지 3개 중 2개 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: 5 단계, 이미지 3개 중 3개
    • Use your spudger to lift and remove the camera lens bracket and loud speaker.
    댓글 쓰기
  6. Samsung Galaxy A03s Screen Replacement, Disconnect battery: 6 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Disconnect battery: 6 단계, 이미지 2개 중 2개
    • Disconnect the battery cable by using a spudger
    댓글 쓰기
  7. Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: 7 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: 7 단계, 이미지 2개 중 2개
    • Use your spudger to disconnect the power button ribbon cable. Remove the power button.
    댓글 쓰기
  8. Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: 8 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: 8 단계, 이미지 2개 중 2개
    • Use your spudger to disconnect and remove the mainboard flex cable.
    댓글 쓰기
  9. Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: 9 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to disconnect and remove the black antenna cable on the mainboard and charging board
    댓글 쓰기
  10. Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: 10 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: 10 단계, 이미지 2개 중 2개
    • Use your spudger to lift and remove mainboard and charging board
    댓글 쓰기
  11. Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: 11 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: 11 단계, 이미지 2개 중 2개
    • Use heat and/or isopropyl alcohol to remove vibrate motor
    댓글 쓰기
  12. Samsung Galaxy A03s Screen Replacement, Remove volume button flex: 12 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Remove volume button flex: 12 단계, 이미지 2개 중 2개
    • Use heat and/or isopropyl alcohol to remove volume button flex
    댓글 쓰기
  13. Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: 13 단계, 이미지 2개 중 1개 Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: 13 단계, 이미지 2개 중 2개
    • Use spudger to remove earpiece speaker
    댓글 쓰기
  14. Samsung Galaxy A03s Screen Replacement, Remove battery: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Use heat and isopropyl alcohol to remove the battery.
    • Be careful to not puncture the battery while removing it.
    • There's a lot of adhesive under this battery and it can be tricky to remove. You can slide a thin plastic card underneath the battery to help break the adhesive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 59명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matea
회원 가입일: 05/05/23
1,909 평판
안내서 1개를 작성함
8가이드 댓글
Actually you guys are making it more complex and difficult than it needs to be or should ever have to be because I've repaired hundreds of Samsung Galaxy a03 s's and all Samsung Galaxy phones for that matter and the way you're going about in depth in detail and specific on a complete breakdown is too complex to be quite frankly honest with you you don't need to do all of this you're doing more work than what is really there honestly.
Harold Peterson - 답글 공유
Are you going to offer the more simple solutions or no?
Missjentri - 답글 공유
Yeah, so do a better job
Timothy Bradford - 답글 공유
Can you post the simplest was to do this?
Chuck - 답글 공유
No carga solo logo de temperatura
Alan Rivera - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 196
지난 30일: 767
전체 시간: 31,903
