주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A3 2016 Battery Replacement
필요한 것
  1. Samsung Galaxy A3 2016 Battery Replacement, Back cover: 1 단계, 이미지 3개 중 1개 Samsung Galaxy A3 2016 Battery Replacement, Back cover: 1 단계, 이미지 3개 중 2개 Samsung Galaxy A3 2016 Battery Replacement, Back cover: 1 단계, 이미지 3개 중 3개
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • Lift the bottom part of your back cover with a suction handle and insert an opening pick.
  2. Samsung Galaxy A3 2016 Battery Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy A3 2016 Battery Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy A3 2016 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the opening pick up to the rear camera to separate the back cover from the frame.
  3. Samsung Galaxy A3 2016 Battery Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy A3 2016 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a second opening pick and move around the other corner at the bottom part of the back cover.
  4. Samsung Galaxy A3 2016 Battery Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy A3 2016 Battery Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy A3 2016 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Move the second pick along the left side of the back cover to loosen the adhesive.
    • Move around the upper left corner and loosen the adhesive above the rear camera.
    • After loosening all the edges and sides of the back cover use an iOpener to loosen the adhesive underneath the center of it.
  5. Samsung Galaxy A3 2016 Battery Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy A3 2016 Battery Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy A3 2016 Battery Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Insert a plastic card at the bottom and slide it underneath the back cover.
    • Separate the glue until you reach the rear camera.
    • Now you can slowly lift up the back cover and finally remove it.
  6. Samsung Galaxy A3 2016 Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 Samsung Galaxy A3 2016 Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the SIM card tray.
    • Remove the 16 Phillips #00 screws on the midframe.
  7. Samsung Galaxy A3 2016 Battery Replacement: 7 단계, 이미지 1개 중 1개
  8. Samsung Galaxy A3 2016 Battery Replacement: 8 단계, 이미지 2개 중 1개 Samsung Galaxy A3 2016 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Push the exposed part of the battery away from the midframe to separate the components.
    • Remove the midframe.
  9. Samsung Galaxy A3 2016 Battery Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy A3 2016 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Insert an opening pick between the battery and the frame. Slide along the battery to separate the adhesive.
    • Don't go too deep with the opening pick to not damage the display underneath.
    • Remove the battery.
    • You may need to apply new adhesive when installing the new battery.
결론
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
다른 44명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
249,500 평판
안내서 682개를 작성함
iFixit EU Team iFixit EU Team 회원
Staff
37 회원들
안내서 1,210개를 작성함
8가이드 댓글
Nice post on Samsung phone. People are courageous about Galaxy phones and there is lot of hype about Samsung.
I bought a budget j7 for my wife and I am sure this will have good review.
not sure why they are not talking about.
Thanks
Rakesh Birchi
Owner of http://www.birchi.in
Birchi In - 답글
Thank you so very much! I'm an ageing priest working in Transylvania and The Republic of moldova with victims of child trafficking. My battery has suffered extensive use and I believe it still should have lasted longer. I have limited resources to use for myself and feel attempting to replace the battery myself far more economical and funds conscious. Thanks to you I shall endeavour to replace it myself…thanks to your instruction.
May all your journeys be ones of discovery!
Fr Bill+
Projectnewlife.org
PNLMoldovaPrisons.blogspot.com
BigWorldSmallBoat.blogspot.com
ScmMoldova.blogspot.com
DogDogma.blogspot.com
Father Bill - 답글
Assolutamente insufficiente. L’iOpener non scioglie l’adesivo posteriore e quindi il vetro posteriore si rompe facilmente. Il tutorial indica una parte assolutamente inutile, ovvero lo smontaggio del telaio. Non serve basta estrarre la batteria con un piccolo cacciavite. I tutorial fateli scrivere a chi lavora sui device. Grazie
axlduri - 답글
Hello axlduri,
thanks for your feedback. In case you weren’t able to loosen the adhesive beneath the back cover with an iOpener, you can use a heat gun to do so. However the iOpener should do the job and should be applied for at least 2 minutes to the back cover. Repeat this step several times until the adhesive is loose. Additionally the battery sits super tight in the mid frame and it’s nearly impossible to remove it safely, without removing the mid frame. You should never work or pry on batteries with metal tools like a screwdriver. If you accidentally puncture them, they can explode or catch fire. Thats the reason why we advise to remove the mid frame. It’s the safest way to remove the battery.
Dominik Schnabelrauch -
Merci pour ces instructions. J’ai essayé de démonter la batterie, mais me suis arrêté à l’étape 6. Je ne comprends pas pourquoi il y a toute cette colle! A quoi servent les vis si tout est collé? Remplacer la batterie était un jeu d’enfant dans les anciens modèles Samsung. Maintenant on a l’impression que les constructeurs font tout pour qu’on désespère et rachète un nouveau mobile! C’est honteux dans un monde où on essaie de minimiser les déchets!
dcprobst - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 111
전체 시간: 120,183
