주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note10+ Rear Camera Module Replacement
필요한 것
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the SIM card: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the SIM card: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the SIM card: 1 단계, 이미지 3개 중 3개
      • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      댓글 쓰기
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Heat the rear cover: 2 단계, 이미지 1개 중 1개
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      댓글 쓰기
    2. Samsung Galaxy Note10+ Rear Camera Module Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      댓글 쓰기
    3. Samsung Galaxy Note10+ Rear Camera Module Replacement, Begin to slice the adhesive: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Begin to slice the adhesive: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Begin to slice the adhesive: 4 단계, 이미지 3개 중 3개
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      댓글 쓰기
    4. Samsung Galaxy Note10+ Rear Camera Module Replacement, Slice around the perimeter of the phone: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Slice around the perimeter of the phone: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Slice around the perimeter of the phone: 5 단계, 이미지 3개 중 3개
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      • The rear cover will begin to separate from the phone as you finish all sides of the phone.
      댓글 쓰기
    5. Samsung Galaxy Note10+ Rear Camera Module Replacement, Lift off the rear cover: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Lift off the rear cover: 6 단계, 이미지 2개 중 2개
      • Lift the rear cover straight up to remove it.
      • Follow this guide to reinstall the rear cover and replace the adhesive.
      • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
      • If you're using Tesa tape to reattach components, follow this guide.
      댓글 쓰기
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Lift up the metal cover: 7 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
      댓글 쓰기
    2. Samsung Galaxy Note10+ Rear Camera Module Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
      댓글 쓰기
    3. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the battery: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the battery: 9 단계, 이미지 2개 중 2개
      • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
      댓글 쓰기
    4. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the wireless charging coil: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the wireless charging coil: 10 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      댓글 쓰기
    5. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the wireless charging coil: 11 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the wireless charging coil: 11 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the wireless charging coil: 11 단계, 이미지 3개 중 3개
      • Tilt the metal shielding up so you can grip it with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the phone with some light adhesive.
      • Remove the wireless charging coil.
      댓글 쓰기
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker screws: 12 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
      댓글 쓰기
    2. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker: 13 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker: 13 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the loudspeaker: 13 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to remove the loudspeaker.
      댓글 쓰기
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the interconnect cables: 14 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the interconnect cables: 14 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the interconnect cables: 14 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      • Disconnect the secondary interconnect cable from the motherboard.
      댓글 쓰기
    2. Samsung Galaxy Note10+ Rear Camera Module Replacement: 15 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 15 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 15 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      • Disconnect the secondary interconnect cable from the daughterboard.
      댓글 쓰기
    3. Samsung Galaxy Note10+ Rear Camera Module Replacement: 16 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 16 단계, 이미지 2개 중 2개
      • Remove both interconnect cables.
      댓글 쓰기
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the top plastic cover: 17 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
      댓글 쓰기
    2. Samsung Galaxy Note10+ Rear Camera Module Replacement: 18 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 18 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 18 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
      댓글 쓰기
    3. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect motherboard connectors: 19 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect motherboard connectors: 19 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect motherboard connectors: 19 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to disconnect the touch layer connector from the motherboard.
      • Disconnect the side button connector from the motherboard.
      댓글 쓰기
    4. Samsung Galaxy Note10+ Rear Camera Module Replacement: 20 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 20 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
      댓글 쓰기
    5. Samsung Galaxy Note10+ Rear Camera Module Replacement: 21 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 21 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      댓글 쓰기
    6. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the motherboard: 22 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the motherboard: 22 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the motherboard: 22 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
      • Remove the motherboard.
      댓글 쓰기
    1. Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the rear camera module: 23 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the rear camera module: 23 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Disconnect the rear camera module: 23 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to remove the small piece of tape covering the middle camera connector.
      댓글 쓰기
    2. Samsung Galaxy Note10+ Rear Camera Module Replacement: 24 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 24 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 24 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to disconnect the bottom camera connector.
      • Disconnect the middle camera connector.
      댓글 쓰기
    3. Samsung Galaxy Note10+ Rear Camera Module Replacement: 25 단계, 이미지 2개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement: 25 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the top camera connector.
      댓글 쓰기
    4. Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the rear camera module: 26 단계, 이미지 3개 중 1개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the rear camera module: 26 단계, 이미지 3개 중 2개 Samsung Galaxy Note10+ Rear Camera Module Replacement, Remove the rear camera module: 26 단계, 이미지 3개 중 3개
      • Use a pair of tweezers or your fingers to remove the rear camera module.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
171,331 평판
안내서 442개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 72,303개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 88
전체 시간: 5,578
