주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note20 Ultra USB-C Port Replacement
필요한 것
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Heat the rear cover: 1 단계, 이미지 1개 중 1개
      • Completely power off your phone before you begin disassembly.
      • Heat an iOpener and apply it to the left side of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
      댓글 쓰기
    2. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      댓글 쓰기
    3. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Begin to cut the adhesive: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Begin to cut the adhesive: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Begin to cut the adhesive: 3 단계, 이미지 3개 중 3개
      • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      댓글 쓰기
    4. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Cut along the perimeter of the rear cover: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Cut along the perimeter of the rear cover: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Cut along the perimeter of the rear cover: 4 단계, 이미지 3개 중 3개
      • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
      • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
      • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
      • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
      댓글 쓰기
    5. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the rear cover: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the rear cover: 5 단계, 이미지 2개 중 2개
      • Lift the rear cover straight up to remove it.
      댓글 쓰기
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the wireless charging coil: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the wireless charging coil: 6 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      댓글 쓰기
    2. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the white press connector: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the white press connector: 7 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
      댓글 쓰기
    3. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the motherboard shield screws: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Magnetic Project Mat
      $19.95
      • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
      • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
      댓글 쓰기
    4. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the wireless charging coil: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the wireless charging coil: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the wireless charging coil: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to lift up the motherboard shield.
      • Be careful when handling the motherboard shield because its edges are thin and sharp.
      • Use your fingers to grip the motherboard shield.
      댓글 쓰기
    5. Samsung Galaxy Note20 Ultra USB-C Port Replacement: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 Ultra USB-C Port Replacement: 10 단계, 이미지 3개 중 3개
      • Peel the wireless charging coil up and away from the device to remove it.
      • The wireless charging coil is secured to the device with light adhesive.
      댓글 쓰기
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the battery: 11 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the battery: 11 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
      댓글 쓰기
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the loudspeaker screws: 12 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the five 4.0 mm screws securing the loudspeaker to the frame.
      댓글 쓰기
    2. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the loudspeaker: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the loudspeaker: 13 단계, 이미지 2개 중 2개
      • Insert the pointed end of a spudger into the hole marked by a triangle on the left side of the loudspeaker.
      • Use the spudger to pry up and loosen the left side of the loudspeaker.
      댓글 쓰기
    3. Samsung Galaxy Note20 Ultra USB-C Port Replacement: 14 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement: 14 단계, 이미지 2개 중 2개
      • Insert the pointed end of a spudger into the hole marked by a triangle on the right side of the loudspeaker.
      • Use the spudger to pry up and detach the loudspeaker from the frame.
      • The loudspeaker is secured to the frame by clips along its bottom edge.
      댓글 쓰기
    4. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the loudspeaker: 15 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to lift and remove the loudspeaker.
      댓글 쓰기
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the interconnect cables from the daughterboard: 16 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the interconnect cables from the daughterboard: 16 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
      댓글 쓰기
    2. Samsung Galaxy Note20 Ultra USB-C Port Replacement: 17 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement: 17 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      댓글 쓰기
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the daughterboard screw: 18 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the 3.0 mm screw securing the daughterboard to the frame.
      댓글 쓰기
    2. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the daughterboard: 19 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the daughterboard: 19 단계, 이미지 2개 중 2개
      • The daughterboard is fitted to the frame by three spring connectors along its bottom edge.
      • Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
      • Use the spudger to pry up and detach the daughterboard from the frame.
      • There are small surface-mounted components underneath the daughterboard. Only insert the spudger as far as necessary to avoid damaging the components.
      댓글 쓰기
    3. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the daughterboard: 20 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the daughterboard: 20 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to lift and remove the daughterboard.
      댓글 쓰기
    1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the main interconnect cable from the motherboard: 21 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the main interconnect cable from the motherboard: 21 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      댓글 쓰기
    2. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Unscrew the USB-C port: 22 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the two 3.0 mm screws securing the USB-C port to the phone.
      댓글 쓰기
    3. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the USB-C port: 23 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the USB-C port: 23 단계, 이미지 2개 중 2개
      • Insert the pointed end of a spudger under the left side screw hole on the USB-C port.
      • Pry up the USB-C port to loosen it from the frame.
      • The USB-C port may fling out of its slot while it is being pried.
      • Avoid scratching the USB-C port's copper pad with your pry tool.
      • The USB-C port is held in place by a red rubber gasket. Prying up with a steady force will gradually loosen the USB-C port from its slot.
      댓글 쓰기
    4. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the USB-C port: 24 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the USB-C port: 24 단계, 이미지 2개 중 2개
      • Grip the USB-C ribbon cable with your fingers close to the USB-C port.
      • Remove the USB-C port by pulling it up and away from the bottom of the phone.
      • Avoid bending the ribbon cable more than necessary to prevent damage.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
Kyle Smith
회원 가입일: 02/01/21
52,625 평판
안내서 124개를 작성함
3가이드 댓글
I would like to also add to this tutorial for the last step after you remove the USB-C Charging port and once you reinstall the port, rather its a new one or the same stock oem port that you took out. You should be extremely cautious to how tight you tighten these screws as the LED Touch Display actually lays flat against the frame and if you over tighten these screws that hold this port down, you will figure out quite easily that 1. the screens are very fragile and 2. these screws are able to be tightened and will not stop causing unwanted pressure onto the screen and will destroy the screen which will make it useless as the phone will work just without a display or touch interactions with the phone until buying a new display to replace it.
Jay - 답글 공유
Big rule of thumb for smartphones, tighten only until it feels snug, don't crank things as tightly as they can go. This was also a problem for iPhone repair, some were cranking as tight as possible and killing their screens. The screws have loctite, they're not going anywhere.
Zack is Back - 답글 공유
This is an excellent article! Many Thanks For Sharing
GBENGA JOSHUA BOLARINWA - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 93
지난 30일: 261
전체 시간: 23,642
