주요 콘텐츠로 건너뛰기
Samsung Galaxy Prevail Headphone Jack Replacement
Ricardo Zuloaga
Ricardo Zuloaga4 다른 기여자
최종 수정일 December 25, 2016
10 - 25 분
조정
잘게 썰기
By following this guide you should be able to replace the headphone jack in 10-20 minutes. By replacing the headphone jack, you will fix any headphone related audio issues such as static, muffled sounds, or poor earphone audio quality.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Samsung Galaxy Prevail Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1개 중 1개
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Headphone Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Headphone Jack Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Headphone Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Using the nylon spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Headphone Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Using the spudger lift the speaker assembly upward, so you may have access to the headphone assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
  6. Samsung Galaxy Prevail Headphone Jack Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Prevail Headphone Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Using the spudger, carefully unplug and remove the headphone port assembly by lifting upward on the ribbon cable.
    • The headphone jack should lift off of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ricardo Zuloaga
회원 가입일: 09/15/16
537 평판
안내서 5개를 작성함
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G6
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 18
전체 시간: 350
