주요 콘텐츠로 건너뛰기
Samsung Galaxy S10e Battery Replacement
필요한 것
  1. Samsung Galaxy S10e Battery Replacement, Heat the back cover: 1 단계, 이미지 1/1
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Turn your phone off completely before you begin this repair.
    • Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S10e Battery Replacement, Prepare to slice the adhesive: 2 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement, Prepare to slice the adhesive: 2 단계, 이미지 2/2
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
    • As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
    • The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
  3. Samsung Galaxy S10e Battery Replacement, Secure a suction cup: 3 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement, Secure a suction cup: 3 단계, 이미지 2/2
    • Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
    • The suction cup will not make a good seal on the curved portion of the glass, so avoid putting it on the very edge.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  4. Samsung Galaxy S10e Battery Replacement, Create an opening gap: 4 단계, 이미지 1/3 Samsung Galaxy S10e Battery Replacement, Create an opening gap: 4 단계, 이미지 2/3 Samsung Galaxy S10e Battery Replacement, Create an opening gap: 4 단계, 이미지 3/3
    • Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • If you're using an iOpener, follow the heating instructions to avoid overheating it, or the gel pack may burst.
    • Press the edge of an opening tool into the gap.
    • The rear glass can break if you use too much force or attempt to pry with metal tools.
  5. Samsung Galaxy S10e Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy S10e Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy S10e Battery Replacement: 5 단계, 이미지 3/3
    • Slide the opening tool along the right edge of the phone to slice through the adhesive securing the back cover.
  6. Samsung Galaxy S10e Battery Replacement: 6 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement: 6 단계, 이미지 2/2
    • Insert an opening pick into the edge next to the opening tool. Leave the pick here to prevent the separated glue from re-adhering.
  7. Samsung Galaxy S10e Battery Replacement: 7 단계, 이미지 1/1
    • Apply a heated iOpener to the top edge of the phone for two minutes.
  8. Samsung Galaxy S10e Battery Replacement: 8 단계, 이미지 1/3 Samsung Galaxy S10e Battery Replacement: 8 단계, 이미지 2/3 Samsung Galaxy S10e Battery Replacement: 8 단계, 이미지 3/3
    • Insert an opening pick near the top right corner of the phone and slide it around the corner and across the top edge of the phone.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to separate it.
    • Leave the opening pick in place to prevent the adhesive from re-adhering.
  9. Samsung Galaxy S10e Battery Replacement: 9 단계, 이미지 1/1
    • Apply a heated iOpener to the left edge of the phone for two minutes.
  10. Samsung Galaxy S10e Battery Replacement: 10 단계, 이미지 1/3 Samsung Galaxy S10e Battery Replacement: 10 단계, 이미지 2/3 Samsung Galaxy S10e Battery Replacement: 10 단계, 이미지 3/3
    • Insert a new opening pick near the top left corner and slide it along the left edge of the phone.
    • Again, leave the opening pick in place in the left edge of the phone to prevent the adhesive from resealing.
  11. Samsung Galaxy S10e Battery Replacement: 11 단계, 이미지 1/1
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
  12. Samsung Galaxy S10e Battery Replacement: 12 단계, 이미지 1/3 Samsung Galaxy S10e Battery Replacement: 12 단계, 이미지 2/3 Samsung Galaxy S10e Battery Replacement: 12 단계, 이미지 3/3
    • Insert an opening pick near a bottom corner of the phone, and slide it along the bottom edge of the phone to separate the adhesive there.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to fully separate it.
  13. Samsung Galaxy S10e Battery Replacement: 13 단계, 이미지 1/3 Samsung Galaxy S10e Battery Replacement: 13 단계, 이미지 2/3 Samsung Galaxy S10e Battery Replacement: 13 단계, 이미지 3/3
    • Use the opening picks to very carefully pry up the back cover.
    • If you encounter any resistance, stop prying and use an opening pick to cut any remaining adhesive.
    • Remove the back cover.
  14. Samsung Galaxy S10e Battery Replacement: 14 단계, 이미지 1/1
    • Follow this guide to reinstall the back cover and replace the adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the leftover adhesive is usually more than strong enough to hold.
  15. Samsung Galaxy S10e Battery Replacement, Remove the midframe: 15 단계, 이미지 1/1
    • Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
  16. Samsung Galaxy S10e Battery Replacement: 16 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement: 16 단계, 이미지 2/2
    • Slide an opening pick under the bottom right corner of the upper midframe to separate the adhesive holding it to the lower midframe.
  17. Samsung Galaxy S10e Battery Replacement: 17 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement: 17 단계, 이미지 2/2
    • Insert the point of a spudger in the small cutout on the right edge of the plastic part of the upper midframe, near the Bixby button.
    • Use the point of the spudger to pry the midframe up from the phone chassis.
  18. Samsung Galaxy S10e Battery Replacement: 18 단계, 이미지 1/1
    • Lift the midframe by the plastic section and remove it from the phone.
    • To reinstall, first insert the top edge of the assembly into the phone's frame, and then gently press down on the rest of the assembly to snap it into place.
  19. Samsung Galaxy S10e Battery Replacement, Disconnect the battery: 19 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement, Disconnect the battery: 19 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the battery connector straight up from its socket and disconnect it.
  20. Samsung Galaxy S10e Battery Replacement, Battery: 20 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement, Battery: 20 단계, 이미지 2/2
    이 단계에 사용된 도구:
    iFixit Adhesive Remover
    $19.99
    구매
    • This step can be completed using either adhesive remover or high concentration (over 90%) isopropyl alcohol.
    • Prop the bottom edge of the phone up to angle the phone so that the adhesive remover will run from the bottom of the battery toward the top.
    • Apply isopropyl alcohol or adhesive remover along the bottom edge of the battery. Allow it to sit for several minutes to allow the adhesive to weaken.
  21. Samsung Galaxy S10e Battery Replacement: 21 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement: 21 단계, 이미지 2/2
    • Use the flat end of a spudger to carefully pry the battery out of the phone.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • If you encounter significant resistance or the battery starts to deform, repeat the last step to further dissolve the adhesive.
  22. Samsung Galaxy S10e Battery Replacement: 22 단계, 이미지 1/2 Samsung Galaxy S10e Battery Replacement: 22 단계, 이미지 2/2
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery and adhesive, follow this guide.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 45명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
199,443 평판
안내서 416개 작성하였습니다
댓글 12개
I was going to publish this guide but somebody did it already for me. Thanks!
By the way the color of that phone in the guide is hideous in my opinion.
Dinan Blueje - 답글
When you say “moderate” difficulty, how what’s making it difficult or where is the risk coming from? With the right tools, patience, and even a small bit of experience replacing a screen in an admittedly easy Nokia Lumia phone, what could go wrong, and what would you recommend?
Mark Stretton - 답글
Hi Mark, the hardest part of this guide is dealing with all the adhesive without damaging anything. The back cover and the battery are both heavily glued down. To get the back cover off without cracking it, I’d recommend plenty of heat and very patient and gentle prying. If the prying gets really tough, try heating the back a little more. Removing the battery can be tough as well, but using adhesive remover helps a lot. Follow the steps in the guide and make sure you give the adhesive remover a few minutes to soak in. If prying gets difficult, add a little more adhesive remover and wait a couple minutes before continuing. Hope that helps!
Adam O'Camb -
We ran into the problem of the octa not seperating with the back glass. We were using the AoD JIG. What do u recommend as the next step in that instance?
rfralin - 답글
If I buy the kit from ifixit, are the battery going to be relatively new? or the batteries have been seating in shelves since OEM days.
Reaz Tahmidur Rahman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 87
7일 전: 493
30일 전: 2,309
전체 시간: 111,702
