주요 콘텐츠로 건너뛰기
Samsung Galaxy S22 Ultra Back Cover Replacement
필요한 것
  1. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the right edge: 1 단계, 이미지 1/1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S22 Ultra Back Cover Replacement, Adhesive information: 2 단계, 이미지 1/2 Samsung Galaxy S22 Ultra Back Cover Replacement, Adhesive information: 2 단계, 이미지 2/2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S22 Ultra Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 3/3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the right adhesive: 4 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the right adhesive: 4 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the right adhesive: 4 단계, 이미지 3/3
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  5. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the bottom edge: 5 단계, 이미지 1/1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 6 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 6 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 6 단계, 이미지 3/3
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  7. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the bottom adhesive: 7 단계, 이미지 1/2 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the bottom adhesive: 7 단계, 이미지 2/2
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the left edge: 8 단계, 이미지 1/1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 9 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 9 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 9 단계, 이미지 3/3
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  10. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the left adhesive: 10 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the left adhesive: 10 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the left adhesive: 10 단계, 이미지 3/3
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the top edge: 11 단계, 이미지 1/1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 12 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 12 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 12 단계, 이미지 3/3
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  13. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the top adhesive: 13 단계, 이미지 1/2 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the top adhesive: 13 단계, 이미지 2/2
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  14. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 14 단계, 이미지 1/2 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: 14 단계, 이미지 2/2
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  15. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the remaining adhesive: 15 단계, 이미지 1/2 Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the remaining adhesive: 15 단계, 이미지 2/2
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  16. Samsung Galaxy S22 Ultra Back Cover Replacement, Remove the back cover: 16 단계, 이미지 1/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Remove the back cover: 16 단계, 이미지 2/3 Samsung Galaxy S22 Ultra Back Cover Replacement, Remove the back cover: 16 단계, 이미지 3/3
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
결론
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 9) to make sure your device is fully functional.
다른 4명이 해당 안내서를 완성하였습니다.
Clay Eickemeyer
회원 가입일: 09/19/22
52,863 평판
안내서 394개 작성하였습니다
iFixit iFixit 회원
Community
142 회원들
안내서 16,232개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 44
7일 전: 305
30일 전: 1,312
전체 시간: 15,123
