주요 콘텐츠로 건너뛰기
Samsung Galaxy S23 Ultra Back Cover Replacement
필요한 것
  1. Samsung Galaxy S23 Ultra Back Cover Replacement, Heat the right edge: 1 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S23 Ultra Back Cover Replacement, Adhesive information: 2 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Adhesive information: 2 단계, 이미지 2개 중 2개
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S23 Ultra Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the right adhesive: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the right adhesive: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the right adhesive: 4 단계, 이미지 3개 중 3개
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S23 Ultra Back Cover Replacement, Heat the bottom edge: 5 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 6 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 6 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 6 단계, 이미지 3개 중 3개
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  7. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the bottom adhesive: 7 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the bottom adhesive: 7 단계, 이미지 2개 중 2개
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S23 Ultra Back Cover Replacement, Heat the left edge: 8 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 9 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 9 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 9 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  10. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the left adhesive: 10 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the left adhesive: 10 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the left adhesive: 10 단계, 이미지 3개 중 3개
    • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S23 Ultra Back Cover Replacement, Heat the top edge: 11 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 12 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 12 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 12 단계, 이미지 3개 중 3개
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  13. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the top adhesive: 13 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the top adhesive: 13 단계, 이미지 2개 중 2개
    • Slide the pick to the top left corner to separate the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  14. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 14 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the corner adhesive: 14 단계, 이미지 2개 중 2개
    • Insert an opening pick in the gap at the top left edge.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  15. Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the remaining adhesive: 15 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Separate the remaining adhesive: 15 단계, 이미지 2개 중 2개
    • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
  16. Samsung Galaxy S23 Ultra Back Cover Replacement, Remove the back cover: 16 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Back Cover Replacement, Remove the back cover: 16 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Back Cover Replacement, Remove the back cover: 16 단계, 이미지 3개 중 3개
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
결론
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,105 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
I didn't need heat. I used a 0.12mm thick metal pick made for removing screens. I was able to get it under the bottom right corner to break the seal. I then started dripping ethanol around the perimeter, following it with a thicker pick to eventually lift off the back cover.
When replacing the back glass, don't forget to rub off the residual glue on the phone, following with more ethanol and microfiber swabs to remove every last rubbery ball of it.
Max Powers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 37
지난 7일: 303
지난 30일: 1,260
전체 시간: 20,196
