주요 콘텐츠로 건너뛰기
Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement
필요한 것
  1. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 3개
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  3. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the right edge: 3 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  4. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Adhesive information: 4 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Adhesive information: 4 단계, 이미지 2개 중 2개
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  5. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  6. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the right adhesive: 6 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the right adhesive: 6 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the right adhesive: 6 단계, 이미지 3개 중 3개
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  7. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the bottom edge: 7 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  8. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 8 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 8 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 8 단계, 이미지 3개 중 3개
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  9. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the bottom adhesive: 9 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the bottom adhesive: 9 단계, 이미지 2개 중 2개
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the left edge: 10 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  11. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 11 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 11 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 11 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  12. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the left adhesive: 12 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the left adhesive: 12 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the left adhesive: 12 단계, 이미지 3개 중 3개
    • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  13. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the top edge: 13 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  14. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 14 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 14 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 14 단계, 이미지 3개 중 3개
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  15. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the top adhesive: 15 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the top adhesive: 15 단계, 이미지 2개 중 2개
    • Slide the pick to the top left corner to separate the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  16. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 16 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: 16 단계, 이미지 2개 중 2개
    • Insert an opening pick in the gap at the top left edge.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  17. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the remaining adhesive: 17 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the remaining adhesive: 17 단계, 이미지 2개 중 2개
    • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
  18. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: 18 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: 18 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: 18 단계, 이미지 3개 중 3개
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: 19 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: 19 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: 19 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  20. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the coil adhesive: 20 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the coil adhesive: 20 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the coil adhesive: 20 단계, 이미지 3개 중 3개
    • The wireless charging coil is lightly adhered to the battery.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  21. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: 21 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: 21 단계, 이미지 2개 중 2개
    • Insert an opening pick between the top edge of the wireless charging coil and the frame.
    • Slide the pick toward the right edge to separate the remaining adhesive.
  22. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unfasten the NFC antenna and charging coil: 22 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  23. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unfasten the loudspeaker: 23 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  24. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: 24 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: 24 단계, 이미지 2개 중 2개
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  25. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: 25 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: 25 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: 25 단계, 이미지 3개 중 3개
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
  26. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: 26 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: 26 단계, 이미지 2개 중 2개
    • Use your spudger to pry up and disconnect the battery press connector.
  27. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: 27 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: 27 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: 27 단계, 이미지 3개 중 3개
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
    • Repeat for the primary interconnect cable.
  28. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: 28 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: 28 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: 28 단계, 이미지 3개 중 3개
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
  29. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: 29 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: 29 단계, 이미지 2개 중 2개
    • Grab and remove the interconnect cables from the frame.
  30. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unfasten the charging board: 30 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  31. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: 31 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: 31 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: 31 단계, 이미지 3개 중 3개
    • Insert the point of your spudger under the top right of the charging board.
    • Pry the charging board up from its recess until you can grab it with your fingers.
    • Pull the charging board toward the top of the device to remove it from its recess.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
결론
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,105 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
4가이드 댓글
Muchas gracias por el conocimiento entregado, de muy buena calidad!!
Sergio Fernández - 답글
I like this repair.i will attempt it when I go home.
walter76108us - 답글
Very helpful guide. The hardest part is just getting it open, but once that was over it was pretty much smooth sailing. I got the iFixit kit and had trouble with the iOpener with getting the back cover off. I'm not sure if it wasn't hot enough, so I resorted to using a hair dryer instead. Otherwise, fantastic guide.
My local Verizon store said it would cost $70 for them to clean the charging port, and if that didn't fix the issue it could be several hundred dollars to repair it. Between the iFixit opening kit, the part on Amazon, and some adhesive, I spend less than $50 plus my time.
Bakazuraz - 답글
How i fix my Samsung s23 ultra WhatsApp microphone while am recording voice note it's not working but when am using
On calling or video call microphone is working but the problem is when am sending voice note it's not come out with voice
Nico Sanga - 답글
댓글 쓰기
조회 통계:
지난 24시간: 40
지난 7일: 195
지난 30일: 819
전체 시간: 13,370
