주요 콘텐츠로 건너뛰기
Samsung Gear 2 Neo Motherboard Replacement
Victor Yore
Victor Yore5 다른 기여자
최종 수정일 August 11, 2017
5 분
쉬움
If your Infrared stops working, your devices' RAM isn't functioning, or if the core of the Gear 2 Neo stops working then this guide will help in replacing the motherboard which have each of these integrated into it. This has a difficulty of 3 out of 10, and should only take about 5 minutes to complete.
필요한 것
부품
도구
더보기...
  1. Samsung Gear 2 Neo Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung Gear 2 Neo Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Samsung Gear 2 Neo Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
  5. Samsung Gear 2 Neo Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
  6. Samsung Gear 2 Neo Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • It is recommended to use antistatic wrist wrap whenever removing the motherboard.
    • Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
    • Attached to the motherboard is the infrared LED Light. To replace the IR LED, you may need to replace the entire motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Victor Yore
회원 가입일: 08/27/15
705 평판
안내서 5개를 작성함
USF Tampa, Team 5-6, Blackwell Fall 2015 USF Tampa, Team 5-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G6
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 2,380
