주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gear Fit Screen Replacement
필요한 것
    1. Samsung Gear Fit Screen Replacement, Watch Band: 1 단계, 이미지 2개 중 1개 Samsung Gear Fit Screen Replacement, Watch Band: 1 단계, 이미지 2개 중 2개
      • Place your thumbs on the ends of the screen.
      • Push the watch outward while pulling the band away from the watch.
      댓글 쓰기
    1. Samsung Gear Fit Screen Replacement, Screen: 2 단계, 이미지 1개 중 1개
      • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
      • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
      • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
      댓글 쓰기
    2. Samsung Gear Fit Screen Replacement: 3 단계, 이미지 3개 중 1개 Samsung Gear Fit Screen Replacement: 3 단계, 이미지 3개 중 2개 Samsung Gear Fit Screen Replacement: 3 단계, 이미지 3개 중 3개
      • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
      • Gently pry the screen loose using a plastic opening tool.
      • If the screen doesn't easily come loose, more heating may be required
      댓글 쓰기
    3. Samsung Gear Fit Screen Replacement: 4 단계, 이미지 3개 중 1개 Samsung Gear Fit Screen Replacement: 4 단계, 이미지 3개 중 2개 Samsung Gear Fit Screen Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using tweezers as a lever, pry the inner assembly out of the external casing.
      • This will be harder than removing the screen. Moderate force may be required.
      댓글 쓰기
    4. Samsung Gear Fit Screen Replacement: 5 단계, 이미지 3개 중 1개 Samsung Gear Fit Screen Replacement: 5 단계, 이미지 3개 중 2개 Samsung Gear Fit Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
      댓글 쓰기
    5. Samsung Gear Fit Screen Replacement: 6 단계, 이미지 2개 중 1개 Samsung Gear Fit Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Gently peel the screen assembly up and away from the device using tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nathan Powell
회원 가입일: 04/24/14
1,584 평판
안내서 3개를 작성함
Cal Poly, Team 11-49, Amido Spring 2014 Cal Poly, Team 11-49, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G49
4 회원들
안내서 28개를 작성함
28가이드 댓글
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - 답글 공유
Where can you buy replacement screen?
Yele Olaniyi - 답글 공유
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - 답글 공유
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - 답글 공유
Does anyone know where to get the replacement screen?
MrGratts - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 33
전체 시간: 54,694
