주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung P241 Power Cable Replacement
필요한 것
    1. Samsung P241 Power Cable Replacement, Top Case: 1 단계, 이미지 2개 중 1개 Samsung P241 Power Cable Replacement, Top Case: 1 단계, 이미지 2개 중 2개
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Samsung P241 Power Cable Replacement: 2 단계, 이미지 2개 중 1개 Samsung P241 Power Cable Replacement: 2 단계, 이미지 2개 중 2개
      • Pull the top cover towards you until you can lift it up and off.
      댓글 쓰기
    1. Samsung P241 Power Cable Replacement, Power Cable: 3 단계, 이미지 2개 중 1개 Samsung P241 Power Cable Replacement, Power Cable: 3 단계, 이미지 2개 중 2개
      • Unclip the power cable from the motherboard and gently pull up to remove.
      댓글 쓰기
    2. Samsung P241 Power Cable Replacement: 4 단계, 이미지 2개 중 1개 Samsung P241 Power Cable Replacement: 4 단계, 이미지 2개 중 2개
      • Once you have unclipped the power cable, use a multimeter (left) to test if the cable is still functional.
      • Turn the dial on the multimeter to continuity test mode.
      • Make sure the positive lead is plugged into the voltmeter/ohmeter outlet.
      댓글 쓰기
    3. Samsung P241 Power Cable Replacement: 5 단계, 이미지 2개 중 1개 Samsung P241 Power Cable Replacement: 5 단계, 이미지 2개 중 2개
      • Use one multimeter lead to touch one of the prongs on the AC side of power cable. Use the other lead to touch one end of the clip side of the power cable.
      • The multimeter will show numbers if there is a good electrical connection. If it does not show any numbers the first time, try using the lead to touch the other prong.
      • Repeat the above directions with the other prong and clip side of the power cable.
      • If the multimeter does not show numbers during any of the connections, your power cable is dead and you will need to replace it.
      댓글 쓰기
    4. Samsung P241 Power Cable Replacement: 6 단계, 이미지 1개 중 1개
      • If you found that the power cable has a good electrical connection, you will have to test that the cable has not shorted out.
      • To do this, touch each prong on the AC side of the power cable. If numbers show on the screen, your power cable is bad and must be replaced.
      • If your power cable is bad, do not replug the cable into the AC outlet.
      • If the cable works, the problem is with the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sarah Wachtfogel
회원 가입일: 01/12/11
340 평판
안내서 3개를 작성함
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 회원
CPSU-FORTE-W11S14G7
5 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 31
전체 시간: 1,606
