주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung RF28R7351 Fuse Block Module Replacement
필요한 것
동영상 개요
    1. Samsung RF28R7351 Fuse Block Module Replacement, Fuse Box Module: 1 단계, 이미지 1개 중 1개
      • Begin by disconnecting the power to the appliance
      • It is also recommended to test the outlet for the proper voltage
      • Also, turn off the water.
      댓글 쓰기
    2. Samsung RF28R7351 Fuse Block Module Replacement: 2 단계, 이미지 1개 중 1개
      • You will need a Phillips screwdriver to remove the cover, which is held on by five Phillips screws.
      • Remove the five Phillips screws.
      • The lower middle screw is a machine screw thread, so keep it separate for reinstallation.
      댓글 쓰기
    3. 댓글 쓰기
    4. Samsung RF28R7351 Fuse Block Module Replacement: 4 단계, 이미지 2개 중 1개 Samsung RF28R7351 Fuse Block Module Replacement: 4 단계, 이미지 2개 중 2개
      • With the panel removed, you now have clear access to the fuse block.
      댓글 쓰기
    5. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: 5 단계, 이미지 2개 중 1개 Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: 5 단계, 이미지 2개 중 2개
      • The main reason why you'd be accessing your fuse block is if the unit has no power
      • Once the fuse block is removed, you can use your multimeter to test continuity on the metal sides of each one of these fuses.
      • (How to use a multimeter)
      • If one is blown, the fuse block will need to be replaced.
      댓글 쓰기
    6. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: 6 단계, 이미지 2개 중 1개 Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: 6 단계, 이미지 2개 중 2개
      댓글 쓰기
    7. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: 7 단계, 이미지 2개 중 1개 Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: 7 단계, 이미지 2개 중 2개
      • When installing your new fuse block, first install the wiring.
      • Make sure the connector is securely locked into place.
      • The red wire goes with the red, and the blue with the blue.
      • Swing it in at an angle and pop it in place.
      댓글 쓰기
    8. Samsung RF28R7351 Fuse Block Module Replacement, Reinstall the panel cover: 8 단계, 이미지 1개 중 1개
      • Once the new fuse block is installed, you can reinstall the panel cover.
      • To reinstall your panel cover, first bring in the top at an angle and drop it on those hooks.
      댓글 쓰기
    9. Samsung RF28R7351 Fuse Block Module Replacement: 9 단계, 이미지 3개 중 1개 Samsung RF28R7351 Fuse Block Module Replacement: 9 단계, 이미지 3개 중 2개 Samsung RF28R7351 Fuse Block Module Replacement: 9 단계, 이미지 3개 중 3개
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
eCuration
회원 가입일: 05/19/17
478,744 평판
안내서 396개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 52
전체 시간: 801
