주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SmartThings Hub USB Port Replacement
필요한 것
  1. Samsung SmartThings Hub USB Port Replacement, USB Port: 1 단계, 이미지 1개 중 1개
    • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
    댓글 쓰기
  2. Samsung SmartThings Hub USB Port Replacement: 2 단계, 이미지 3개 중 1개 Samsung SmartThings Hub USB Port Replacement: 2 단계, 이미지 3개 중 2개 Samsung SmartThings Hub USB Port Replacement: 2 단계, 이미지 3개 중 3개
    • Make sure the batteries are removed before attempting disassembly.
    • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
    • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
    댓글 쓰기
  3. Samsung SmartThings Hub USB Port Replacement: 3 단계, 이미지 3개 중 1개 Samsung SmartThings Hub USB Port Replacement: 3 단계, 이미지 3개 중 2개 Samsung SmartThings Hub USB Port Replacement: 3 단계, 이미지 3개 중 3개
    • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
    댓글 쓰기
  4. Samsung SmartThings Hub USB Port Replacement: 4 단계, 이미지 2개 중 1개 Samsung SmartThings Hub USB Port Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
    댓글 쓰기
  5. Samsung SmartThings Hub USB Port Replacement: 5 단계, 이미지 3개 중 1개 Samsung SmartThings Hub USB Port Replacement: 5 단계, 이미지 3개 중 2개 Samsung SmartThings Hub USB Port Replacement: 5 단계, 이미지 3개 중 3개
    • Place the motherboard on a clean, flat surface.
    • Preheat your soldering iron. Each USB port has eight points of connection to the motherboard (pictured above). Using your soldering iron, apply heat to each solder joint in turn while pulling the USB port away from the board.
    • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
    • For more information on soldering refer to How To Solder and Desolder Connections.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Erin
회원 가입일: 09/28/17
494 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,054
