주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung WB1100F Motherboard Replacement
필요한 것
    1. Samsung WB1100F Motherboard Replacement, LCD Screen Cover: 1 단계, 이미지 2개 중 1개 Samsung WB1100F Motherboard Replacement, LCD Screen Cover: 1 단계, 이미지 2개 중 2개
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      댓글 쓰기
    2. Samsung WB1100F Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung WB1100F Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      댓글 쓰기
    1. Samsung WB1100F Motherboard Replacement, LCD Screen: 3 단계, 이미지 2개 중 1개 Samsung WB1100F Motherboard Replacement, LCD Screen: 3 단계, 이미지 2개 중 2개
      • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
      댓글 쓰기
    2. Samsung WB1100F Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung WB1100F Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung WB1100F Motherboard Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Flip the LCD screen over to reveal the display cable.
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
      • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      댓글 쓰기
    1. Samsung WB1100F Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Remove two 1.2 Phillips #00 screws connected to the motherboard.
      댓글 쓰기
    2. Samsung WB1100F Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Desolder five wires connected to the camera motherboard.
      댓글 쓰기
    3. Samsung WB1100F Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung WB1100F Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Use the tip of a spudger or your fingernail to flip up the small retaining flaps on the five ZIF connectors on the motherboard.
      • Detach the five ribbon cables from the camera motherboard.
      • The white line on the ribbon cables mark the edge of the connection area. To reinstall, insert the cables into the connector up to this line, and then close the retaining flap. If a cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      댓글 쓰기
    4. Samsung WB1100F Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Gently remove the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jesse Lindsey
회원 가입일: 05/13/16
581 평판
안내서 5개를 작성함
Metro State, Team 1-1, Carpenter SU 2016 Metro State, Team 1-1, Carpenter SU 2016 회원
MSU-CARPENTER-SU16S1G1
3 회원들
안내서 5개를 작성함
1가이드 댓글
Great Jesse, I can say the same applies for the WB100, I get one and I already disassembly it to fix humidity condensation in the top buttons, unfortunately the flash stops working..
Congratulation for your post. Enrique
egyr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 38
전체 시간: 1,639
