주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Watch Active Battery Replacement
필요한 것
  1. Samsung Watch Active Battery Replacement, Turn off the watch: 1 단계, 이미지 2개 중 1개 Samsung Watch Active Battery Replacement, Turn off the watch: 1 단계, 이미지 2개 중 2개
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    댓글 쓰기
  2. Samsung Watch Active Battery Replacement, Remove the rear screws: 2 단계, 이미지 1개 중 1개
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    댓글 쓰기
  3. Samsung Watch Active Battery Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 3개
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    댓글 쓰기
  4. Samsung Watch Active Battery Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 1개 Samsung Watch Active Battery Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 2개
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    댓글 쓰기
  5. Samsung Watch Active Battery Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
    댓글 쓰기
  6. Samsung Watch Active Battery Replacement, Disconnect the motherboard: 6 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Disconnect the motherboard: 6 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Disconnect the motherboard: 6 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to disconnect the display assembly, the microphone and pressure sensor array, and side button.
    댓글 쓰기
  7. Samsung Watch Active Battery Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 3개
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    댓글 쓰기
  8. Samsung Watch Active Battery Replacement, Remove the motherboard screw: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
    댓글 쓰기
  9. Samsung Watch Active Battery Replacement, Loosen the motherboard: 9 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Loosen the motherboard: 9 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Loosen the motherboard: 9 단계, 이미지 3개 중 3개
    • Use an opening pick to loosen the motherboard from the core assembly.
    • The plastic tab holding the motherboard in place is fragile, so don't lift the motherboard up until it has cleared the tab.
    댓글 쓰기
  10. Samsung Watch Active Battery Replacement, Remove the motherboard: 10 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Remove the motherboard: 10 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Remove the motherboard: 10 단계, 이미지 3개 중 3개
    • Slide the motherboard out from under the plastic tab to remove it.
    댓글 쓰기
  11. Samsung Watch Active Battery Replacement, Lift the battery: 11 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Lift the battery: 11 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Lift the battery: 11 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the bottom of the battery and the core frame.
    • The battery is secured with some mild adhesive.
    • Use the spudger to lever up the battery.
    댓글 쓰기
  12. Samsung Watch Active Battery Replacement, Remove the battery: 12 단계, 이미지 3개 중 1개 Samsung Watch Active Battery Replacement, Remove the battery: 12 단계, 이미지 3개 중 2개 Samsung Watch Active Battery Replacement, Remove the battery: 12 단계, 이미지 3개 중 3개
    • Remove the battery from the core assembly.
    • The battery connector is fixed with mild adhesive.
    • When installing a new battery make sure the tiny hole on the battery connector aligns with the pin on the core frame.
    댓글 쓰기
결론
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
134,382 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,238개를 작성함
1가이드 댓글
Good guide! With a few modifications, usable for the Samsung Active Watch 2. The only pitfall with the Active watch 2 is the small solder ribbon cable on the underside of the motherboard that could tear if you try to remove the board completely
anghofus - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 26
지난 30일: 117
전체 시간: 12,873
