주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Watch Active Screen Assembly Replacement
필요한 것
  1. Samsung Watch Active Screen Assembly Replacement, Turn off the watch: 1 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Assembly Replacement, Turn off the watch: 1 단계, 이미지 2개 중 2개
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    댓글 쓰기
  2. Samsung Watch Active Screen Assembly Replacement, Remove the rear screws: 2 단계, 이미지 1개 중 1개
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    댓글 쓰기
  3. Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 3개
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    댓글 쓰기
  4. Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 2개
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    댓글 쓰기
  5. Samsung Watch Active Screen Assembly Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
    댓글 쓰기
  6. Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: 6 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: 6 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: 6 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
    댓글 쓰기
  7. Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 3개
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    댓글 쓰기
  8. Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: 8 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: 8 단계, 이미지 2개 중 2개
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
    댓글 쓰기
  9. Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 3개
    • Lift out and remove the core assembly.
    댓글 쓰기
  10. Samsung Watch Active Screen Assembly Replacement, Loosen the mic: 10 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Assembly Replacement, Loosen the mic: 10 단계, 이미지 2개 중 2개
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
    댓글 쓰기
  11. Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: 11 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: 11 단계, 이미지 2개 중 2개
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
    댓글 쓰기
  12. Samsung Watch Active Screen Assembly Replacement, Remove the mic array: 12 단계, 이미지 1개 중 1개
    • Carefully remove the microphone and barometric sensor array from the frame.
    댓글 쓰기
  13. Samsung Watch Active Screen Assembly Replacement, Screen Assembly: 13 단계, 이미지 1개 중 1개
    • You’re left with the screen assembly.
    • Make sure to compare the new screen assembly to the old one for any parts that need to be transferred.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
134,346 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,238개를 작성함
13가이드 댓글
These instructions look very good! My screen has several cracks and I want to replace the front module. Do you have any idea where I can order one?
Jantine Stulp - 답글 공유
Yes there s one on eBay for $31.76 https://www.google.com/aclk?sa=l&ai=DChc...
Dylan Austin - 답글 공유
My screen was black or showing static. I disassembled and reassembled and now it's back to normal. Might have been a bad internal connection.
Benjamin Franzmayr - 답글 공유
Think I have the same issue may have to try opening it. Do you still have it? Is it still good?
Simon Hall - 답글 공유
this is a rather silly question, but which model is that diode on the LCD panel? I couldn't find the schematics for the screen
Thomas Jungblut - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 34
지난 30일: 131
전체 시간: 18,423
