주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Watch Active Screen Replacement
필요한 것
  1. Samsung Watch Active Screen Replacement, Turn off the watch: 1 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Replacement, Turn off the watch: 1 단계, 이미지 2개 중 2개
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    댓글 쓰기
  2. Samsung Watch Active Screen Replacement, Remove the rear screws: 2 단계, 이미지 1개 중 1개
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    댓글 쓰기
  3. Samsung Watch Active Screen Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 3개
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    댓글 쓰기
  4. Samsung Watch Active Screen Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 2개
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    댓글 쓰기
  5. Samsung Watch Active Screen Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
    댓글 쓰기
  6. Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: 6 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: 6 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: 6 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
    댓글 쓰기
  7. Samsung Watch Active Screen Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Replacement, Undo the mic tape: 7 단계, 이미지 3개 중 3개
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    댓글 쓰기
  8. Samsung Watch Active Screen Replacement, Lift the core assembly: 8 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Replacement, Lift the core assembly: 8 단계, 이미지 2개 중 2개
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
    댓글 쓰기
  9. Samsung Watch Active Screen Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 3개
    • Lift out and remove the core assembly.
    댓글 쓰기
  10. Samsung Watch Active Screen Replacement, Loosen the mic: 10 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Replacement, Loosen the mic: 10 단계, 이미지 2개 중 2개
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
    댓글 쓰기
  11. Samsung Watch Active Screen Replacement, Free the barometric sensor: 11 단계, 이미지 2개 중 1개 Samsung Watch Active Screen Replacement, Free the barometric sensor: 11 단계, 이미지 2개 중 2개
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
    댓글 쓰기
  12. Samsung Watch Active Screen Replacement, Remove the mic array: 12 단계, 이미지 1개 중 1개
    • Carefully remove the microphone and barometric sensor array from the frame.
    댓글 쓰기
  13. Samsung Watch Active Screen Replacement, Loosen the screen adhesive: 13 단계, 이미지 1개 중 1개
    댓글 쓰기
  14. Samsung Watch Active Screen Replacement, Separate the screen and frame: 14 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Replacement, Separate the screen and frame: 14 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Replacement, Separate the screen and frame: 14 단계, 이미지 3개 중 3개
    • Insert the opening tool under the frame where the sensor array was located.
    • Pry upwards to separate the screen from the frame.
    댓글 쓰기
  15. Samsung Watch Active Screen Replacement, Remove the screen: 15 단계, 이미지 3개 중 1개 Samsung Watch Active Screen Replacement, Remove the screen: 15 단계, 이미지 3개 중 2개 Samsung Watch Active Screen Replacement, Remove the screen: 15 단계, 이미지 3개 중 3개
    • Use your fingers to pull the frame off the remaining screen adhesive.
    • Clean any remaining adhesive from the frame using isopropyl alcohol (>90%) before installing the new screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
134,346 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,238개를 작성함
3가이드 댓글
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Rosalie E. Morgan - 답글 공유
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
Colm O'Sullivan - 답글 공유
How do I put the mic array back in?
Mason Thomas - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 38
지난 30일: 159
전체 시간: 6,603
