주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sanyo VPC-S1415 LCD Replacement
필요한 것
    1. Sanyo VPC-S1415 LCD Replacement, LCD: 1 단계, 이미지 3개 중 1개 Sanyo VPC-S1415 LCD Replacement, LCD: 1 단계, 이미지 3개 중 2개 Sanyo VPC-S1415 LCD Replacement, LCD: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Here is a recently acquired camera. Initial cost $3.00
      • Only trouble is, obviously broken LCD
      • Remove the carrying strip. Use a needle and some tweezers to loosen the slip knot.
      댓글 쓰기
    2. Sanyo VPC-S1415 LCD Replacement: 2 단계, 이미지 3개 중 1개 Sanyo VPC-S1415 LCD Replacement: 2 단계, 이미지 3개 중 2개 Sanyo VPC-S1415 LCD Replacement: 2 단계, 이미지 3개 중 3개
      • Remove one screw on the right of the camera
      • Remove one screw on the left side of the camera
      • Remove the two screws on the bottom
      댓글 쓰기
    3. Sanyo VPC-S1415 LCD Replacement: 3 단계, 이미지 3개 중 1개 Sanyo VPC-S1415 LCD Replacement: 3 단계, 이미지 3개 중 2개 Sanyo VPC-S1415 LCD Replacement: 3 단계, 이미지 3개 중 3개
      • Split the camera from the battery compartment down. You can use an opening tools, or just your fingernails, if so equipped.
      • This will remove the front part of the case.
      • Remove this screw on the right side of the camera. Keep it separate from the 4 screws previously removed. The are of different length
      댓글 쓰기
    4. Sanyo VPC-S1415 LCD Replacement: 4 단계, 이미지 3개 중 1개 Sanyo VPC-S1415 LCD Replacement: 4 단계, 이미지 3개 중 2개 Sanyo VPC-S1415 LCD Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the screw on the bottom of the battery compartment. Keep this screw with the one removed on the previous step. These two screws have a different length than all the other screws. They are the shortest ones in the camera
      • With those two screws removed, you can not separate the back part of the case.
      • Flip the LCD to the right and out of the frame. Do NOT try to remove it yet.
      • Remove the screw screws that hold the LCD frame to the logic board. Keep the 3 screws separated from the rest of the screws, due to different length.
      댓글 쓰기
    5. Sanyo VPC-S1415 LCD Replacement: 5 단계, 이미지 3개 중 1개 Sanyo VPC-S1415 LCD Replacement: 5 단계, 이미지 3개 중 2개 Sanyo VPC-S1415 LCD Replacement: 5 단계, 이미지 3개 중 3개
      • With the frame removed, the connector and LCD cable are now fully accessible. Note the to tabs on the cable and their position on the logic board.
      • Flip the tab on the connector carefully up and remove the LCD.
      • Hopefully this is what you will get after replacing the LCD and reassembling the camera in reverse order. Total replacement cost was $15 and 30 minutes of my time.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
858,719 평판
안내서 123개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 2,673
