주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Screen Replacement
필요한 것
  1. Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Screen Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove masking tape from the battery.
  4. Screen Replacement: 4 단계, 이미지 3개 중 1개 Screen Replacement: 4 단계, 이미지 3개 중 2개 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Screen Replacement: 5 단계, 이미지 3개 중 1개 Screen Replacement: 5 단계, 이미지 3개 중 2개 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. 연결부 납땜 및 납제거 방법
    • Use caution when operating the soldering iron.
  6. Screen Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Screen Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Screen Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Screen Replacement: 8 단계, 이미지 3개 중 1개 Screen Replacement: 8 단계, 이미지 3개 중 2개 Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
  9. Screen Replacement, Screen: 9 단계, 이미지 1개 중 1개
    • Use the nut driver and the J0 bit to unscrew the four 4 mm screws
  10. Screen Replacement: 10 단계, 이미지 2개 중 1개 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • If your are replacing a broken screen be careful when handling broken glass.
    • Remove the screen from the front cover of the device. At this point there should be no other component holding the screen down.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walker Karstens
회원 가입일: 10/30/16
364 평판
안내서 3개를 작성함
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G1
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 32
지난 30일: 90
전체 시간: 3,379
