주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sega Dreamcast Fan Replacement
필요한 것
  1. Sega Dreamcast Fan Replacement, Expansion Bay: 1 단계, 이미지 2개 중 1개 Sega Dreamcast Fan Replacement, Expansion Bay: 1 단계, 이미지 2개 중 2개
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
    댓글 쓰기
  2. Sega Dreamcast Fan Replacement: 2 단계, 이미지 3개 중 1개 Sega Dreamcast Fan Replacement: 2 단계, 이미지 3개 중 2개 Sega Dreamcast Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    댓글 쓰기
  3. Sega Dreamcast Fan Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
    댓글 쓰기
  4. Sega Dreamcast Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
    댓글 쓰기
  5. Sega Dreamcast Fan Replacement, Fan: 5 단계, 이미지 1개 중 1개
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
    댓글 쓰기
  6. Sega Dreamcast Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
    댓글 쓰기
  7. Sega Dreamcast Fan Replacement: 7 단계, 이미지 2개 중 1개 Sega Dreamcast Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
    댓글 쓰기
  8. Sega Dreamcast Fan Replacement, Fan: 8 단계, 이미지 2개 중 1개 Sega Dreamcast Fan Replacement, Fan: 8 단계, 이미지 2개 중 2개
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Thorr686
회원 가입일: 11/06/09
528 평판
안내서 2개를 작성함
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 18
지난 30일: 95
전체 시간: 20,600
