주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Flex DuoClean Motor Replacement
필요한 것
  1. Shark Flex DuoClean Motor Replacement, Garage Door: 1 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motor Replacement, Garage Door: 1 단계, 이미지 2개 중 2개
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
    댓글 쓰기
  2. Shark Flex DuoClean Motor Replacement, Side Component: 2 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motor Replacement, Side Component: 2 단계, 이미지 2개 중 2개
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
    댓글 쓰기
  3. Shark Flex DuoClean Motor Replacement: 3 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    댓글 쓰기
  4. Shark Flex DuoClean Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
    댓글 쓰기
  5. Shark Flex DuoClean Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the side component with your hands.
    댓글 쓰기
  6. Shark Flex DuoClean Motor Replacement, Top Component: 6 단계, 이미지 1개 중 1개
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
    댓글 쓰기
  7. Shark Flex DuoClean Motor Replacement: 7 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motor Replacement: 7 단계, 이미지 2개 중 2개
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
    댓글 쓰기
  8. Shark Flex DuoClean Motor Replacement, Brush Motor: 8 단계, 이미지 2개 중 1개 Shark Flex DuoClean Motor Replacement, Brush Motor: 8 단계, 이미지 2개 중 2개
    • Orient the vacuum so you are looking down at the open garage of the vacuum.
    • Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
    댓글 쓰기
  9. Shark Flex DuoClean Motor Replacement: 9 단계, 이미지 1개 중 1개
    • With both thumbs, push the gear on the right side of the motor into the vacuum. The motor should pop out.
    • Slowly pull the motor out of the vacuum base and reveal the electrical cords.
    댓글 쓰기
  10. Shark Flex DuoClean Motor Replacement: 10 단계, 이미지 1개 중 1개
    • To fully remove the motor, cut the wires.
    • For reassembly, use the soldering guide in the Introduction.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Samantha Mickelson
회원 가입일: 10/08/18
496 평판
안내서 4개를 작성함
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 회원
CPSU-WHITE-F18S17G5
4 회원들
안내서 25개를 작성함
7가이드 댓글
Can this motor we test it before taking it out
craigfranz - 답글 공유
Can this motor be tested before taking it out?
craigfranz - 답글 공유
How do I know if the motor is burned out
Danny Manuele - 답글 공유
Will you be able to take out the brush roll in front of the motor?
CAM BAP - 답글 공유
Great fix. I wonder if you know how to find a replacement motor? My Dyson motor died and I’m not sure where to start looking for a replacement part - Dyson don’t sell it.
TyN - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 102
전체 시간: 24,834
