주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sharper Image iPulse SI325 LED Lights Replacement
필요한 것
    1. Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: 1 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: 1 단계, 이미지 2개 중 2개
      • Gently position the device so that the buttons and speakers lie face down.
      • Unplug the power cord from the "DC Input."
      댓글 쓰기
    2. Sharper Image iPulse SI325 LED Lights Replacement: 2 단계, 이미지 3개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement: 2 단계, 이미지 3개 중 2개 Sharper Image iPulse SI325 LED Lights Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
      • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
      • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
      • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
      • A small gap will open as the two tabs are released.
      • Do not pull the two halves apart yet. They are held together by the speaker wire.
      댓글 쓰기
    3. Sharper Image iPulse SI325 LED Lights Replacement: 3 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement: 3 단계, 이미지 2개 중 2개
      • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
      • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
      • Lay the device down, so that all the internal components are facing upwards.
      댓글 쓰기
    1. Sharper Image iPulse SI325 LED Lights Replacement, Speakers: 4 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement, Speakers: 4 단계, 이미지 2개 중 2개
      • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
      • Wiggling the connector back and forth as you pull will make removal easier.
      댓글 쓰기
    2. Sharper Image iPulse SI325 LED Lights Replacement: 5 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
      댓글 쓰기
    1. Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: 6 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: 6 단계, 이미지 2개 중 2개
      • Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights.
      • Slowly lift the circuit board out of the front cover and place the cover out of the way.
      댓글 쓰기
    2. Sharper Image iPulse SI325 LED Lights Replacement: 7 단계, 이미지 2개 중 1개 Sharper Image iPulse SI325 LED Lights Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the solder connecting the LED light that needs replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Melissa Pasa
회원 가입일: 10/13/13
701 평판
안내서 7개를 작성함
Cal Poly, Team 11-33, Amido Fall 2013 Cal Poly, Team 11-33, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G33
4 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 35
전체 시간: 771
