주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shure SM58 XLR Connector Replacement
필요한 것
    1. Shure SM58 XLR Connector Replacement, Connector: 1 단계, 이미지 3개 중 1개 Shure SM58 XLR Connector Replacement, Connector: 1 단계, 이미지 3개 중 2개 Shure SM58 XLR Connector Replacement, Connector: 1 단계, 이미지 3개 중 3개
      • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
      • Make sure you are not holding the microphone connector by the wires.
      • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
      댓글 쓰기
    2. Shure SM58 XLR Connector Replacement: 2 단계, 이미지 2개 중 1개 Shure SM58 XLR Connector Replacement: 2 단계, 이미지 2개 중 2개
      • Hold the microphone connector in one hand and the microphone base in the other.
      • Line up the screw in the connector with the hole in the middle of the microphone.
      • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
      댓글 쓰기
    3. Shure SM58 XLR Connector Replacement: 3 단계, 이미지 2개 중 1개 Shure SM58 XLR Connector Replacement: 3 단계, 이미지 2개 중 2개
      • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
      • Do not push the microphone past this point or the connector may become stuck.
      댓글 쓰기
    4. Shure SM58 XLR Connector Replacement: 4 단계, 이미지 1개 중 1개
      • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
      댓글 쓰기
결론
Following these steps should reinstall the XLR connector back into the microphone.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
nat coll
회원 가입일: 09/27/12
859 평판
안내서 14개를 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 61개를 작성함
2가이드 댓글
kmusic - 답글 공유
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 25
지난 30일: 90
전체 시간: 19,508
