주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skytex SP728 Battery Replacement
필요한 것
  1. Skytex SP728 Battery  Replacement, Case: 1 단계, 이미지 1개 중 1개
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
    댓글 쓰기
  2. Skytex SP728 Battery  Replacement: 2 단계, 이미지 1개 중 1개
    • Using a small phillips screwdriver, unscrew both end screws
    댓글 쓰기
  3. Skytex SP728 Battery  Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
    댓글 쓰기
  4. Skytex SP728 Battery  Replacement: 4 단계, 이미지 1개 중 1개
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
    댓글 쓰기
  5. Skytex SP728 Battery  Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the yellow and black tape around the battery very carefully
    댓글 쓰기
  6. Skytex SP728 Battery  Replacement: 6 단계, 이미지 2개 중 1개 Skytex SP728 Battery  Replacement: 6 단계, 이미지 2개 중 2개
    • Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
    • Follow the link below for additional soldering information 연결부 납땜 및 납제거 방법
    • Soldering uses heat so make sure you are careful while doing it. Also, excessive heat can damage the components. So do not apply the soldering iron on a component for extended periods of time.
    댓글 쓰기
  7. Skytex SP728 Battery  Replacement: 7 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, lift up the battery from right edge and set aside.
    • Make sure that you take the battery out very carefully without bending it or damaging it as it contains toxic chemicals.
    • While soldering the wires for the new battery, remember that the red wire has to be connected to the positive terminal and the black wire has to be connected to the negative terminal.
    댓글 쓰기
결론
To reassemble your device with a new battery, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Galika Adhikari
회원 가입일: 01/21/15
248 평판
안내서 2개를 작성함
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 회원
USFT-BROWN-W15S5G1
4 회원들
안내서 11개를 작성함
1가이드 댓글
Money gimme now
Brayden Spiller - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 38
전체 시간: 1,008
