주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Solio CLASSIC2 USB Port Replacement
필요한 것
    1. Solio CLASSIC2 USB Port Replacement, Disconnecting the Battery: 1 단계, 이미지 1개 중 1개
      • Turn off the device by pressing on the clear power button behind the device.
      • To make sure that it is off, make sure the button is not flashing green.
      댓글 쓰기
    2. Solio CLASSIC2 USB Port Replacement: 2 단계, 이미지 1개 중 1개
      • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
      댓글 쓰기
    3. Solio CLASSIC2 USB Port Replacement: 3 단계, 이미지 3개 중 1개 Solio CLASSIC2 USB Port Replacement: 3 단계, 이미지 3개 중 2개 Solio CLASSIC2 USB Port Replacement: 3 단계, 이미지 3개 중 3개
      • Using the plastic opening tools, gently pry open the side of the large panel.
      • Keeping the tool in, slowly slide the tool along the side of the panel.
      댓글 쓰기
    4. Solio CLASSIC2 USB Port Replacement: 4 단계, 이미지 2개 중 1개 Solio CLASSIC2 USB Port Replacement: 4 단계, 이미지 2개 중 2개
      • Rotate the device 180 degrees.
      • Make sure the opening on other side of the device does not snap closed.
      • Gently slide the plastic opening tool along the side of the panel.
      댓글 쓰기
    5. Solio CLASSIC2 USB Port Replacement: 5 단계, 이미지 2개 중 1개 Solio CLASSIC2 USB Port Replacement: 5 단계, 이미지 2개 중 2개
      • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
      • Using both hands, slowly pull apart the back panel from the rest of the device.
      • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
      댓글 쓰기
    6. Solio CLASSIC2 USB Port Replacement: 6 단계, 이미지 2개 중 1개 Solio CLASSIC2 USB Port Replacement: 6 단계, 이미지 2개 중 2개
      • Softly pinch the red and blue wires close to the white connector.
      • To pull the wires out, wiggle them back and forth until the connector is fully out.
      댓글 쓰기
    1. Solio CLASSIC2 USB Port Replacement, Circuit Board: 7 단계, 이미지 1개 중 1개
      • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Solio CLASSIC2 USB Port Replacement: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
      • Gently lift the circuit board out of the device using tweezers.
      댓글 쓰기
    1. Solio CLASSIC2 USB Port Replacement, USB Port: 9 단계, 이미지 1개 중 1개
      • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
      • Remove solder from both spots on outside of the USB port.
      • Remove solder from base of the USB port.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Anthony Ramos
회원 가입일: 10/20/13
102 평판
안내서 1개를 작성함
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G28
4 회원들
안내서 44개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 1,634
