주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-BX510 Wi-Fi Module Replacement
필요한 것
    1. Sony BDP-BX510 Wi-Fi Module Replacement, Outer Cover: 1 단계, 이미지 1개 중 1개
      • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
      댓글 쓰기
    2. Sony BDP-BX510 Wi-Fi Module Replacement: 2 단계, 이미지 2개 중 1개 Sony BDP-BX510 Wi-Fi Module Replacement: 2 단계, 이미지 2개 중 2개
      • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
      • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
      • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
      • Do not use too much force to remove the tray cover as you may break it.
      댓글 쓰기
    3. Sony BDP-BX510 Wi-Fi Module Replacement: 3 단계, 이미지 2개 중 1개 Sony BDP-BX510 Wi-Fi Module Replacement: 3 단계, 이미지 2개 중 2개
      • Turn to the back of the device.
      • Remove the two 7mm Phillips #2 screws.
      • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
      댓글 쓰기
    4. Sony BDP-BX510 Wi-Fi Module Replacement: 4 단계, 이미지 3개 중 1개 Sony BDP-BX510 Wi-Fi Module Replacement: 4 단계, 이미지 3개 중 2개 Sony BDP-BX510 Wi-Fi Module Replacement: 4 단계, 이미지 3개 중 3개
      • Turn the device so you can see the bottom.
      • Unclip the three black plastic clips on the bottom of the device.
      • Unclip one clip on each side of the device.
      댓글 쓰기
    5. Sony BDP-BX510 Wi-Fi Module Replacement: 5 단계, 이미지 1개 중 1개
      • Slide the cover forward to remove.
      댓글 쓰기
    1. Sony BDP-BX510 Wi-Fi Module Replacement, Port Board: 6 단계, 이미지 1개 중 1개
      • Find the large ribbon cable that connects the port board to the motherboard.
      • Carefully pull directly upwards to disconnect the cable.
      댓글 쓰기
    2. Sony BDP-BX510 Wi-Fi Module Replacement: 7 단계, 이미지 1개 중 1개
      • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
      댓글 쓰기
    3. Sony BDP-BX510 Wi-Fi Module Replacement: 8 단계, 이미지 1개 중 1개
      • Unclip the metal piece on the lower right corner by gently lifting it up.
      댓글 쓰기
    4. Sony BDP-BX510 Wi-Fi Module Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the port board by simply pulling it away from the device.
      댓글 쓰기
    1. Sony BDP-BX510 Wi-Fi Module Replacement, Wi-Fi Module: 10 단계, 이미지 1개 중 1개
      • Pull the cable that attaches the Wi-Fi module to the motherboard.
      • The cable will be hard to remove, so pull hard but carefully.
      댓글 쓰기
    2. Sony BDP-BX510 Wi-Fi Module Replacement: 11 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the single 5mm screw that holds Wi-Fi module to the device.
      댓글 쓰기
    3. Sony BDP-BX510 Wi-Fi Module Replacement: 12 단계, 이미지 1개 중 1개
      • Carefully remove the Wi-Fi module from the device.
      • Avoid getting fingerprints on the module.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Niki Ngosi
회원 가입일: 01/19/20
375 평판
안내서 3개를 작성함
York University, Team S1-G10, Woodhouse Winter 2020 York University, Team S1-G10, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G10
2 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 27
전체 시간: 619
