주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-s7200 Disk Drive Replacement
필요한 것
    1. Sony BDP-s7200 Disk Drive Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the disk tray cover from the device.
      댓글 쓰기
    2. Sony BDP-s7200 Disk Drive Replacement: 2 단계, 이미지 2개 중 1개 Sony BDP-s7200 Disk Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
      • Remove the metal cover.
      댓글 쓰기
    3. Sony BDP-s7200 Disk Drive Replacement: 3 단계, 이미지 2개 중 1개 Sony BDP-s7200 Disk Drive Replacement: 3 단계, 이미지 2개 중 2개
      • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
      댓글 쓰기
    4. Sony BDP-s7200 Disk Drive Replacement: 4 단계, 이미지 1개 중 1개
      • Pull off the back panel and remove it from the device.
      댓글 쓰기
    1. Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: 5 단계, 이미지 3개 중 1개 Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: 5 단계, 이미지 3개 중 2개 Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: 5 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, open one of the tabs on the bottom of the device.
      • While keeping the tab open, insert a opening pick in between the opening tool and tab.
      • Repeat this for the 3 other tabs.
      댓글 쓰기
    2. Sony BDP-s7200 Disk Drive Replacement: 6 단계, 이미지 2개 중 1개 Sony BDP-s7200 Disk Drive Replacement: 6 단계, 이미지 2개 중 2개
      • Place your hands on the two black circles on the bottom of the device.
      • Pull on the black circles to remove the device from its front panel cover.
      댓글 쓰기
    3. Sony BDP-s7200 Disk Drive Replacement: 7 단계, 이미지 3개 중 1개 Sony BDP-s7200 Disk Drive Replacement: 7 단계, 이미지 3개 중 2개 Sony BDP-s7200 Disk Drive Replacement: 7 단계, 이미지 3개 중 3개
      • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
      • Using the same screwdriver, remove the three 9mm screws from the back of the device.
      • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
      댓글 쓰기
    4. Sony BDP-s7200 Disk Drive Replacement: 8 단계, 이미지 2개 중 1개 Sony BDP-s7200 Disk Drive Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the small metal clip on the front of the device.
      • Remove the metal cover on the top of the device.
      댓글 쓰기
    1. Sony BDP-s7200 Disk Drive Replacement, Disk Drive: 9 단계, 이미지 2개 중 1개 Sony BDP-s7200 Disk Drive Replacement, Disk Drive: 9 단계, 이미지 2개 중 2개
      • Using the Phillips #2 Screwdriver, unscrew the four 9mm screws from disk drive.
      • Disconnect the 3 ribbon cables connecting the disk drive to the motherboard
      • Pull the disk drive from the device to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erik Preston
회원 가입일: 01/16/20
412 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 30
전체 시간: 1,160
