Sony Cyber-Shot DSC-H200 Battery Replacement
The Sony Cyber-shot DSC-H200 comes with removable AA batteries that will need to be replaced periodically. This guide will help you learn how to replace the batteries, by first opening the SD door.
필요한 것
Push the SD Door switch toward OPEN with right thumb.
While you do this simultaneously press the SD Door switch away from the center of the camera with your left thumb (the SD door will open).
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Are there specific (brand) batteries that work with this camera? I
ve used panasonic bqcc55 rechargables but no success
