주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-TX9 Flash Replacement
Yegor Shea
Yegor Shea4 다른 기여자
최종 수정일 May 7, 2024
5 - 10 분
조정
액션 샷
This repair will solve any problems related to flash malfunctions. For example if the flash is not responding or the flash is not as bright as it should be, this repair will fix these issues.
필요한 것
도구
더보기...
  1. Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: 1 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: 1 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Flash Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX9 Flash Replacement: 2 단계, 이미지 2개 중 2개
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Flash Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Flash Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-TX9 Flash Replacement: 4 단계, 이미지 2개 중 2개
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (케이블 커넥터 인식 및 분리) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: 5 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: 5 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: 5 단계, 이미지 3개 중 3개
    • Remove the two screws for the metal plate on the bottom.
    • Detach the no fuse ribbon cables by sliding them out.
    • Detach the ZIF connector cables by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Remove ribbons slowly and carefully or they WILL rip.
    • Screws are of Phillips type, head size Y0 and 0.3 mm in length.
  6. Sony Cyber-Shot DSC-TX9 Flash Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-TX9 Flash Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-TX9 Flash Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Carefully remove the Memory card circuit board. You will then be able to see the flash with the capacitors connected.
    • Using tweezers, carefully remove the components. They are all connected together.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
결론
작성자
4다른 기여자 명과 함께
Yegor Shea
회원 가입일: 03/26/17
301 평판
안내서 3개를 작성함
UMass Dartmouth, Team S4-G3, Julie Spring 2017 UMass Dartmouth, Team S4-G3, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G3
5 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 7
전체 시간: 376
