Sony Cyber-shot DSC-H200 Motherboard Replacement
To replace the motherboard correctly, users must get to the motherboard by first removing the LCD screen and metal plate behind it. To begin, please refer to the LCD Screen prerequisite guide to find the proper steps for the LCD removal process.
Using a screwdriver, remove the five 6mm screws located on the back panel.
Using a screwdriver, remove the two 3mm screws located on the back panel.
이 단계에 사용된 도구:Tweezers$4.99
Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
다른 3명이 해당 안내서를 완성하였습니다.
