주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H200 Tripod Port Replacement
Chantilly Higbee
Chantilly Higbee5 다른 기여자
최종 수정일 May 7, 2024
30 분
조정
잘게 썰기
The tripod port may be loose, broken or faulty. In any case, replacement of the tripod port involves first removing the LCD Screen and the Motherboard. Please refer to the LCD Screen prerequisite guide and the Motherboard prerequisite guide for proper removal of the LCD Screen and the Motherboard.
필요한 것
도구
더보기...
  1. Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 2 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 3 단계, 이미지 1개 중 1개
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H200 Tripod Port Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 5 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 6 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H200 Tripod Port Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 9 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H200 Tripod Port Replacement: 9 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H200 Tripod Port Replacement: 9 단계, 이미지 3개 중 3개
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
  10. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
  11. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 11 단계, 이미지 1개 중 1개
    • Disconnect all wires from the motherboard by using a soldering iron.
    • Users unfamiliar with a soldering iron should be extremely careful as the device can get very hot.
  12. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 12 단계, 이미지 1개 중 1개
    • Gently lift the motherboard away from the camera body.
  13. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Tripod Port: 13 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the four 4mm screws from the motherboard.
    • Then remove the single 4mm screw connecting the motherboard to the main body of the camera.
  14. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the motherboard away from the camera body (the tripod port is exposed)
  15. Sony Cyber-shot DSC-H200 Tripod Port Replacement: 15 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H200 Tripod Port Replacement: 15 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H200 Tripod Port Replacement: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, lift the tripod port up and away from the camera body
결론
작성자
5다른 기여자 명과 함께
Chantilly Higbee
회원 가입일: 04/08/15
152 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 17
전체 시간: 1,314
