주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H300 Batteries Replacement
Zachary Meyer
Zachary Meyer3 다른 기여자
최종 수정일 April 8, 2024
3 분
매우 쉬움
This is a step by step guide showing exactly how to replace the batteries located inside the camera. This guide is relatively easy and shouldn't take very much time. If the camera is displaying incorrect battery percentages or dies unexpectedly please check out the troubleshooting guide for assistance.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Sony Cyber-shot DSC-H300 Batteries Replacement, Batteries: 1 단계, 이미지 1개 중 1개
    • Flip the camera over to look at the bottom side.
  2. Sony Cyber-shot DSC-H300 Batteries Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H300 Batteries Replacement: 2 단계, 이미지 2개 중 2개
    • Place thumb on battery cover and slide outward until it springs open.
    Battery opening will not spring open
    John Greenwood - 답글
    Same! What was your resolve?
    William Foltz -
  3. Sony Cyber-shot DSC-H300 Batteries Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the batteries.
    How do you charge the camera? I’ve tried and I can’t seem to figure it out
    Mona Said - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zachary Meyer
회원 가입일: 02/14/18
479 평판
안내서 3개를 작성함
USF Tampa, Team S1-G6, Nance Spring 2018 USF Tampa, Team S1-G6, Nance Spring 2018 회원
USFT-NANCE-S18S1G6
3 회원들
안내서 10개를 작성함
댓글 7개
I got the Sony Cyber-shot DSC-H300. I didn't see any battery charge pack in it, only the batteries.
Please I want to know if I'm required to charge the batteries or only replace them when they discharge
Nee Nath - 답글
This uses AA batteries. I’m sure you could use rechargeable batteries as well but I just replace them
Terri S. -
My battery door won't open. It was working until now. Any suggestions?
jer2911alexis - 답글
For any one with this issue it might mean you batteries might have leaked and you can check if there is any white colored residue at the unlock button if , as with my camera i saw some residue, after using something that will not leave marks to push it to unlock position and try to force it a bit to the side the cover, just enough to push something in the edge of cover and housing on the underside near edge of battery cover hinge , to push out the cover a bit more to the side so it slides out to open it and then lift up , just have to clean out the residue of leaked battery of everything in special metal battery contacts on the battery cover , i am trying to find out if there are any replacement parts to replace the metal battery contacts, as i haven`t seen anything yet here
shydar -
The camera door will no longer spring ooen. Any suggestions?
jer2911alexis - 답글
Does Sony make rechargeable battery packs for this camera?
Sue Smith - 답글
Maybe you guys are doing it the wrong way! I was trying to open it from the side. I finally opened it from the part next to the hole and it opened immediately. 😭😭
YourLocalGogi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 39
지난 30일: 175
전체 시간: 10,980
