소개
This repair guide will number and display the steps to remove the Motherboard for replacement.
부품
지정된 부품이 없습니다.
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
