주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia X10 LCD Display Replacement
필요한 것
동영상 개요
  1. Sony Ericsson Xperia X10 LCD Display Replacement, Logic Board: 1 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement, Logic Board: 1 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement, Logic Board: 1 단계, 이미지 3개 중 3개
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Sony Ericsson Xperia X10 LCD Display Replacement: 2 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement: 2 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Sony Ericsson Xperia X10 LCD Display Replacement: 3 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement: 3 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Sony Ericsson Xperia X10 LCD Display Replacement: 4 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement: 4 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
  5. Sony Ericsson Xperia X10 LCD Display Replacement, LCD Display: 5 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement, LCD Display: 5 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement, LCD Display: 5 단계, 이미지 3개 중 3개
    • Unstuck the Touchscreen flex cable from the LCD Display Frame.
    • Use only plastic tools for this operation to avoid damage to the cable.
    • You can use hot air to make the separation easier.
    • Disassemble the Home buttons flex cable & Plastic Bracket to release the Touchscreen Flex cable.
  6. Sony Ericsson Xperia X10 LCD Display Replacement: 6 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement: 6 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Plastic Pry or other plastic tool to separate the LCD Display with Frame from the Front Touchscreen Housing.
    • Do this carefully.
  7. Sony Ericsson Xperia X10 LCD Display Replacement: 7 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement: 7 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the Menu / Camera buttons flex cable.
    • Use again hot air and carefully unstick the LCD Display flex cable from the frame.
  8. Sony Ericsson Xperia X10 LCD Display Replacement: 8 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 LCD Display Replacement: 8 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 LCD Display Replacement: 8 단계, 이미지 3개 중 3개
결론
작성자
1다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,072 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 1,267
