주요 콘텐츠로 건너뛰기
Sony FDL-220R Watchman Button Replacement
Sam Putnam
Sam Putnam2 다른 기여자
최종 수정일 January 9, 2015
10 분
조정
This guide will show you how to clean and/or replace the buttons and switches on the Sony FDL-220R Watchman. Steps include basic disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver and a solution of warm water and baking soda.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 1 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 1 단계, 이미지 2개 중 2개
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: 2 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove screws: 2 단계, 이미지 2개 중 2개
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: 3 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove back casing: 3 단계, 이미지 2개 중 2개
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: 4 단계, 이미지 3개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 4 단계, 이미지 3개 중 2개 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 4 단계, 이미지 3개 중 3개
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 5 단계, 이미지 2개 중 1개 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 5 단계, 이미지 2개 중 2개
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
결론
작성자
2다른 기여자 명과 함께
Sam Putnam
회원 가입일: 10/22/14
484 평판
안내서 4개를 작성함
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G5
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 274
