주요 콘텐츠로 건너뛰기
Sony NEX-5R Main Navigation Button Replacement
Emily Trujillo
Emily Trujillo5 다른 기여자
최종 수정일 May 7, 2024
15 - 20 분
조정
The removal of the main navigation button involves removing the rear casing and carefully prying off the button as to not damage the sensitive components.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: 2 단계, 이미지 1개 중 1개
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: 4 단계, 이미지 1개 중 1개
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: 5 단계, 이미지 2개 중 1개 Sony NEX-5R Main Navigation Button Replacement: 5 단계, 이미지 2개 중 2개
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: 6 단계, 이미지 1개 중 1개
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: 7 단계, 이미지 1개 중 1개
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: 8 단계, 이미지 2개 중 1개 Sony NEX-5R Main Navigation Button Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: 9 단계, 이미지 2개 중 1개 Sony NEX-5R Main Navigation Button Replacement: 9 단계, 이미지 2개 중 2개
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Emily Trujillo
회원 가입일: 04/08/14
1,114 평판
안내서 6개를 작성함
Cal Poly, Team 8-9, Regan Spring 2014 Cal Poly, Team 8-9, Regan Spring 2014 회원
CPSU-REGAN-S14S8G9
4 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 50
전체 시간: 4,057
