주요 콘텐츠로 건너뛰기
Sony NEX-5R Top Panel Replacement
Steven Fronczak
Steven Fronczak3 다른 기여자
최종 수정일 February 12, 2021
15 분
조정
The removal of the top panel involves the removal of the front case to be able to reach the screws necessary for the removal of the top panel.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony NEX-5R Top Panel Replacement, Front Case: 1 단계, 이미지 2개 중 1개 Sony NEX-5R Top Panel Replacement, Front Case: 1 단계, 이미지 2개 중 2개
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Top Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Top Panel Replacement: 3 단계, 이미지 2개 중 1개 Sony NEX-5R Top Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Top Panel Replacement, Rear Case: 4 단계, 이미지 1개 중 1개
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Top Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Top Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
    We already removed the screw next to battery lock. The one close to blue plastic lock.
    Harbert Wolfstein - 답글
    How to repair this part of the interior pack if my blue thing is broken
    @AntoineTy - 답글
  7. Sony NEX-5R Top Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Top Panel Replacement: 8 단계, 이미지 2개 중 1개 Sony NEX-5R Top Panel Replacement: 8 단계, 이미지 2개 중 2개
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
    Pull the back pannel up starting at the bottom of the frame. There is a little hinge at inside the frame the top that will move up and make it much easier to remove the back panel (almost without effort)
    meertdavid - 답글
    The most difficult part of this disassembly is this plastic part. Very thin, flimsy and tend to easily break. Pay extra attention when prying this frame, especially the top part, between the screen hinges.
    Update to my previous comment:
    Remove the top case part where the shutter button, play button etc so that flimsy plastic frame can come out easily.
  9. Sony NEX-5R Top Panel Replacement: 9 단계, 이미지 1개 중 1개
    • The back case should now be removed and look like this.
    Does this part contain battery stopper?
    Gennady - 답글
    I guess not. battery stopper is on the body.
    Chau Jieying -
  10. Sony NEX-5R Top Panel Replacement, Top Panel: 10 단계, 이미지 1개 중 1개
    • Remove the 3.5mm phillips head screw underneath the flash port
  11. Sony NEX-5R Top Panel Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the 3.5mm phillips head screw on the top left of the camera.
  12. Sony NEX-5R Top Panel Replacement: 12 단계, 이미지 1개 중 1개
    • Use the spudger tool to go around the seam of the top panel. The top should easily lift off.
  13. Sony NEX-5R Top Panel Replacement: 13 단계, 이미지 2개 중 1개 Sony NEX-5R Top Panel Replacement: 13 단계, 이미지 2개 중 2개
    • This is what the camera and top panel should look like after you have completed the guide
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Steven Fronczak
회원 가입일: 04/08/14
322 평판
안내서 1개를 작성함
Cal Poly, Team 8-9, Regan Spring 2014 Cal Poly, Team 8-9, Regan Spring 2014 회원
CPSU-REGAN-S14S8G9
4 회원들
안내서 14개를 작성함
1가이드 댓글
Hey Steven! This is all wrong! That's not the wright order: actually the top panel is the first part that can be removed, you don't need to tear down the rear panel and the front handgrip.. (it also may cause the damage of the rear panel!).
So, in order to remove the top panel just follow this order:
STEP 2
STEP 5 (Just the upper screw (not that one between HDMI and USB port)
STEP 6 (Just the two 4mm screws)
STEP 10
STEP 12
Its a lot easier ;)
Daniele
Daniele Fior - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 21
전체 시간: 2,588
