주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony RM-LVR1 Motherboard Replacement
필요한 것
    1. Sony RM-LVR1 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
      • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
      댓글 쓰기
    2. Sony RM-LVR1 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Battery is the rectangular and silver object in the center of device.
      • Remove battery with finger by prying at the rear.
      • If unable to remove battery, pry out using spudger.
      댓글 쓰기
    1. Sony RM-LVR1 Motherboard Replacement, LCD Screen: 3 단계, 이미지 2개 중 1개 Sony RM-LVR1 Motherboard Replacement, LCD Screen: 3 단계, 이미지 2개 중 2개
      • Unscrew the 3 (three) screws holding the bracket in place.
      • Then remove the bracket by prying one end up.
      • Do not rip the ribbon cable connecting the bracket to the motherboard.
      댓글 쓰기
    2. Sony RM-LVR1 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • With tweezers, unplug the ribbon cable from the white connector.
      댓글 쓰기
    3. Sony RM-LVR1 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
      댓글 쓰기
    4. Sony RM-LVR1 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Gently push out on these two clips holding the LCD to the motherboard
      • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
      • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
      댓글 쓰기
    5. Sony RM-LVR1 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Sony RM-LVR1 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
      댓글 쓰기
    6. Sony RM-LVR1 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the screen from the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexander Thomas
회원 가입일: 09/28/17
265 평판
안내서 2개를 작성함
1가이드 댓글
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 677
