주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Vaio PCG-F420 Keyboard Replacement
필요한 것
  1. Sony Vaio PCG-F420 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
    댓글 쓰기
  2. Sony Vaio PCG-F420 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
    댓글 쓰기
  3. Sony Vaio PCG-F420 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
    댓글 쓰기
  4. Sony Vaio PCG-F420 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
    댓글 쓰기
  5. Sony Vaio PCG-F420 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
    댓글 쓰기
  6. Sony Vaio PCG-F420 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
    댓글 쓰기
  7. Sony Vaio PCG-F420 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
    댓글 쓰기
  8. Sony Vaio PCG-F420 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Sony Vaio PCG-F420 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
    댓글 쓰기
  9. Sony Vaio PCG-F420 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Andrew Quayle
회원 가입일: 04/15/10
44 평판
안내서 2개를 작성함
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G77
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 43
전체 시간: 2,965
