Nintendo Wii Wi-Fi Antennas Replacement
Use this guide to replace the two antennas responsible for providing Wi-Fi connectivity.
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
이 단계에 사용된 도구:Tweezers$4.99
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
Lift the side of the Wi-Fi board furthest away from the heat sink and lift it out of its socket on the motherboard, being careful not to put too much sideways force on the connector.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
After I pry the antenna's off then what
