주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement
필요한 것
  1. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: 1 단계, 이미지 2개 중 1개 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: 1 단계, 이미지 2개 중 2개
    • Remove the six silver 11.4 mm Phillips #0 screws
    • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    댓글 쓰기
  2. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Styrofoam Pad: 2 단계, 이미지 1개 중 1개
    • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Do this carefully to avoid tearing the pad.
    댓글 쓰기
  3. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: 3 단계, 이미지 3개 중 1개 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: 3 단계, 이미지 3개 중 2개 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: 3 단계, 이미지 3개 중 3개
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
    댓글 쓰기
  4. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: 4 단계, 이미지 3개 중 1개 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: 4 단계, 이미지 3개 중 2개 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: 4 단계, 이미지 3개 중 3개
    • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
    • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
    댓글 쓰기
  5. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Un-Soldering the Wires: 5 단계, 이미지 1개 중 1개
    • On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
    • Need Help Soldering? Check out 연결부 납땜 및 납제거 방법 for tips.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Andrew Gittens
회원 가입일: 09/22/14
143 평판
안내서 4개를 작성함
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 회원
USFT-BROWN-F14S4G5
3 회원들
안내서 12개를 작성함
1가이드 댓글
Where do you get the replacement parts?
clsutliff - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 787
