주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Steam Controller (2nd Gen, 2026) Right Trigger Replacement
필요한 것
  1. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 1 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 1 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 1 단계, 이미지 3개 중 3개
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    댓글 쓰기
  2. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    TR6 Torx Security Screwdriver
    $5.99
    댓글 쓰기
  3. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover: 3 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover: 3 단계, 이미지 2개 중 2개
    • Remove the back cover.
    댓글 쓰기
  4. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 4 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 4 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 4 단계, 이미지 3개 중 3개
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    댓글 쓰기
  5. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket screws: 5 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket screws: 5 단계, 이미지 2개 중 2개
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    댓글 쓰기
  6. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket: 6 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket: 6 단계, 이미지 2개 중 2개
    댓글 쓰기
  7. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 7 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 7 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 7 단계, 이미지 3개 중 3개
    • The right trigger will be on your left-hand side since the controller is laying upside down.
    • With one hand, fully depress the right trigger.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
    댓글 쓰기
  8. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 8 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 8 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 8 단계, 이미지 3개 중 3개
    • Remove the right trigger.
    • The spring will likely stick to the trigger's magnet.
    • If the spring stayed on its post, leave it in place.
    • During reassembly, make sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
Spencer Day
회원 가입일: 09/14/22
196,232 평판
안내서 1,243개를 작성함
1가이드 댓글
What are the lengths and diameters of the springs? Making them stiffer is what I want to do as they do feel a bit too soft.
Deividas “IHickUp” Misevicius - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 71
지난 30일: 405
전체 시간: 1,087
