주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Switch Pro Controller Motherboard Replacement
필요한 것
  1. Switch Pro Controller Motherboard Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    댓글 쓰기
  2. Switch Pro Controller Motherboard Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 3개
    • Carefully remove the handle covers by pulling them away from the main body.
    댓글 쓰기
  3. Switch Pro Controller Motherboard Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    댓글 쓰기
  4. Switch Pro Controller Motherboard Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 3개
    • Carefully pry away the clear plastic cover using your fingernail.
    댓글 쓰기
  5. Switch Pro Controller Motherboard Replacement, Remove the clear plastic cover: 5 단계, 이미지 1개 중 1개
    • Remove the clear plastic cover.
    댓글 쓰기
  6. Switch Pro Controller Motherboard Replacement, Remove the battery: 6 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Remove the battery: 6 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Remove the battery: 6 단계, 이미지 3개 중 3개
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    댓글 쓰기
  7. Switch Pro Controller Motherboard Replacement, Remove the screws: 7 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Remove the screws: 7 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Remove the screws: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    댓글 쓰기
  8. Switch Pro Controller Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    댓글 쓰기
  9. Switch Pro Controller Motherboard Replacement, Open the flap: 9 단계, 이미지 2개 중 1개 Switch Pro Controller Motherboard Replacement, Open the flap: 9 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    댓글 쓰기
  10. Switch Pro Controller Motherboard Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 1개 Switch Pro Controller Motherboard Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    댓글 쓰기
  11. Switch Pro Controller Motherboard Replacement, Remove the front case: 11 단계, 이미지 1개 중 1개
    • Remove the front case.
    댓글 쓰기
  12. Switch Pro Controller Motherboard Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 3개
    • With light force pull the two joystick caps off of the controller.
    댓글 쓰기
  13. Switch Pro Controller Motherboard Replacement, Loosen the adhesive: 13 단계, 이미지 2개 중 1개 Switch Pro Controller Motherboard Replacement, Loosen the adhesive: 13 단계, 이미지 2개 중 2개
    • Insert the tip of a spudger from the back into the hole on the right controller handle.
    • Push the spudger through the hole to loosen the adhesive which is holding rumble modules in their places.
    댓글 쓰기
  14. Switch Pro Controller Motherboard Replacement, Loosen the adhesive: 14 단계, 이미지 2개 중 1개 Switch Pro Controller Motherboard Replacement, Loosen the adhesive: 14 단계, 이미지 2개 중 2개
    • Insert the tip of a spudger from the back into the hole on the left controller handle.
    댓글 쓰기
  15. Switch Pro Controller Motherboard Replacement, Lift the modules: 15 단계, 이미지 2개 중 1개 Switch Pro Controller Motherboard Replacement, Lift the modules: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair tweezers to lift the modules out of their places.
    댓글 쓰기
  16. Switch Pro Controller Motherboard Replacement, Unscrew the motherboard: 16 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the four 5 mm-long screws securing the motherboard.
    댓글 쓰기
  17. Switch Pro Controller Motherboard Replacement, Remove the LED light: 17 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Remove the LED light: 17 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Remove the LED light: 17 단계, 이미지 3개 중 3개
    • Use your thumb or a pair of tweezers to to take off the white LED light housing.
    댓글 쓰기
  18. Switch Pro Controller Motherboard Replacement, Lift the motherboard: 18 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Lift the motherboard: 18 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Lift the motherboard: 18 단계, 이미지 3개 중 3개
    • Lift the motherboard carefully as to not damage the wires and flip it to reveal the backside.
    댓글 쓰기
  19. Switch Pro Controller Motherboard Replacement, Desolder the rumble modules: 19 단계, 이미지 3개 중 1개 Switch Pro Controller Motherboard Replacement, Desolder the rumble modules: 19 단계, 이미지 3개 중 2개 Switch Pro Controller Motherboard Replacement, Desolder the rumble modules: 19 단계, 이미지 3개 중 3개
    • Desolder the rumble motor solder points on either side of the motherboard.
    • Remove the rumble modules.
    • Refer to the following solder guide if necessary: How to Solder
    • Solder the new rumble modules into the same pins.
    댓글 쓰기
  20. Switch Pro Controller Motherboard Replacement, Desolder the main power cable: 20 단계, 이미지 2개 중 1개 Switch Pro Controller Motherboard Replacement, Desolder the main power cable: 20 단계, 이미지 2개 중 2개
    • Remove the main power cable from the highlighted pins by de-soldering them.
    • Remove the motherboard.
    • Refer to the following solder guide if necessary: How to Solder.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
1가이드 댓글
maybe a tutorial about how you change the usb c port since there are no videos about the pro controller replacement anywhere
Del Meg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 90
지난 30일: 450
전체 시간: 25,460
