주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
System76 Serval WS Cooling Fan Replacement
필요한 것
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1개 중 1개
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
    댓글 쓰기
  2. System76 Serval WS Cooling Fan Replacement: 2 단계, 이미지 2개 중 1개 System76 Serval WS Cooling Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
    댓글 쓰기
  3. System76 Serval WS Cooling Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
    댓글 쓰기
  4. System76 Serval WS Cooling Fan Replacement: 4 단계, 이미지 2개 중 1개 System76 Serval WS Cooling Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    댓글 쓰기
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Oliver Anderson
회원 가입일: 03/26/19
289 평판
안내서 3개를 작성함
UMass Dartmouth, Team S1-G4, Valliere Spring 2019 UMass Dartmouth, Team S1-G4, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S1G4
4 회원들
안내서 3개를 작성함
1가이드 댓글
What model of fan would one buy to replace this?
CrustyTrombone - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 35
전체 시간: 1,304
