주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-Nspire Battery Replacement
필요한 것
    1. TI-Nspire Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
      • Slide the front cover down to remove it.
      댓글 쓰기
    2. TI-Nspire Battery Replacement: 2 단계, 이미지 2개 중 1개 TI-Nspire Battery Replacement: 2 단계, 이미지 2개 중 2개
      • The calculator should be facing front with the screen on the top and the keypad on the bottom.
      • Hold the long side of the calculator on the right or left and turn it 180 degrees so that the back of the calculator faces you.
      • Make sure that the current side facing you is the back by checking that the side has a "reset" button.
      댓글 쓰기
    3. TI-Nspire Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
      • Slide the switch until it moves from the left side of the button area all the way to the right side.
      • Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
      댓글 쓰기
    4. TI-Nspire Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Turn the calculator back to the front as you would normally use it.
      댓글 쓰기
    5. TI-Nspire Battery Replacement: 5 단계, 이미지 2개 중 1개 TI-Nspire Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Put your hand on the keypad, slide the keypad down about a half inch, and pull up to remove the keypad.
      댓글 쓰기
    6. TI-Nspire Battery Replacement: 6 단계, 이미지 1개 중 1개
      • The batteries should be on the right and left side in the keypad area, with two on each side.
      • Place the tip of your finger in between the batteries, and remove the batteries. Repeat this for the other side as well.
      댓글 쓰기
    7. TI-Nspire Battery Replacement: 7 단계, 이미지 1개 중 1개
      • When reassembling your device, use four new batteries.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. If your calculator doesn't turn on, it could be that the keypad isn't connected properly. If so, refer to Connecting the Keypad.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clincy Cheung
회원 가입일: 09/26/12
223 평판
안내서 1개를 작성함
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 회원
CPSU-FORTE-F12S7G52
5 회원들
안내서 33개를 작성함
1가이드 댓글
what should i do if it just stopped all of a sudden and my battery isn’t like that? Its a square not like A++
nenene kldbfssm - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 41
전체 시간: 18,107
