주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tapwave T2907US Zodiac 2 Shoulder Button Replacement
필요한 것
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the four Torx T5 screws from the back panel.
      댓글 쓰기
    2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 2 단계, 이미지 1개 중 1개
      • Wedge a spudger in between the front and back panel.
      • Apply leverage downwards to the spudger in order to remove the back panel.
      댓글 쓰기
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Slide the battery out from under the brown wire-tape.
      • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
      댓글 쓰기
    2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
      댓글 쓰기
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Unscrew the 2 Philips #00 screws on each end of the motherboard.
      댓글 쓰기
    2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Pull off the black memory card slot piece with tweezers.
      댓글 쓰기
    3. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 7 단계, 이미지 1개 중 1개
      • Unscrew the 2 Philips #00 screws on each side of the charging port.
      댓글 쓰기
    4. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 8 단계, 이미지 2개 중 1개 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 8 단계, 이미지 2개 중 2개
      • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
      댓글 쓰기
    5. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 9 단계, 이미지 1개 중 1개
      • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
      • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
      댓글 쓰기
    6. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 10 단계, 이미지 1개 중 1개
      • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
      댓글 쓰기
    7. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 11 단계, 이미지 3개 중 1개 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 11 단계, 이미지 3개 중 2개 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 11 단계, 이미지 3개 중 3개
      • Disconnect the large brown wire-tape from the motherboard.
      • Peel the black tape back from the wire-tape using tweezers.
      • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
      • The screen and motherboard components can now be separated from each other.
      댓글 쓰기
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Shoulder Button: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Desoldering Pump
      $3.99
      • Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
      • Try to avoid contact between the solder sucker and other components surrounding the shoulder buttons.
      • For more information on desoldering, look at this soldering/desoldering guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Daniel Wiseman
회원 가입일: 01/20/12
133 평판
안내서 6개를 작성함
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G33
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 1,263
